    Read own API Key in UIFlow/micropython?
    11 Posts 5 Posters 18.6k Views 1 Watching
    • U Offline
      utaani
      We have set up a number of M5 Stick Cs for remote IT education purposes. We have developed a cloud service for device management, and it is now possible to send a mac address (as a unique ID) from UIFlow to our cloud service using http. If we can upload the UIFlow API Key for each device at the same time as the macaddress, we think that we can distribute the m5f file to the managed M5 Stick C without having the students make notes.
      Is there a way to access the device's API Key from Block or micropython?
        robalstona
        Try
        print(APIKEY)
        #or
        print(_APIKEY)
        Should work. On device boot in serial monitor was displayed all boot messages includes apikey.
        U 1 Reply Last reply Reply Quote 0
        • U Offline
          utaani @robalstona
          @robalstona Thanks for reply.
          I tried the following code, but I get an error.
          from m5stack import *
          from m5ui import *
          from uiflow import *
          setScreenColor(0x111111)
          print(APIKEY)
          "_APIKEY" also resulted in an error.
          Do I need to install any additional modules?
          • IAMLIUBOI Offline
            IAMLIUBO
            Try:
            import deviceCfg
            print("APIKEY: " + deviceCfg.get_apikey())
            But the APIKEY not fixed.I think you should use MAC addr for the devices:
            import machine
            import binascii
            mac_addr = binascii.hexlify(machine.unique_id()).decode('utf-8')
            • U Offline
              utaani @IAMLIUBO
              @iamliubo, Thanks for reply!
              By using this code, I was able to get the API Key:
              import deviceCfg
              akey=deviceCfg.get_apikey()
              BTW, the MAC address can be obtained with the following code:
              macaddr=wifiCfg.wlan_sta.config('mac')
              macaddr='{:02x}:{:02x}:{:02x}:{:02x}:{:02x}:{:02x}'.format(*macaddr)
              Thank you!
              • L Offline
                labixiaoxin8888
                Hello, how about accessing the device's API key from Blockly? Is it possible? I am using M5 Stack new Stamp Pico.
                  ajb2k3 @labixiaoxin8888
                  @labixiaoxin8888 No need as the API key is stuck on the front of the stamp.
                  If you install Thonny and run the terminal monitor, the API's for any device connected will be shown in the terminal for Micropython.
                  • L Offline
                    labixiaoxin8888 @ajb2k3
                    @ajb2k3 Alright, thank you!
                    • L Offline
                      labixiaoxin8888
                      @ajb2k3 Is it possible to print any output for UI flow remote control website?
                        There is an experimental feature of Micropython called webRPEL
                        • L Offline
                          @ajb2k3 Thanks!
