    Read own API Key in UIFlow/micropython?
    UIFlow
    5
    11
    15.5k
    • R
      robalstona
      Try
      print(APIKEY)
      #or
      print(_APIKEY)
      Should work. On device boot in serial monitor was displayed all boot messages includes apikey.
      U 1 Reply Last reply Reply Quote 0
      • U
        utaani @robalstona
        @robalstona Thanks for reply.
        I tried the following code, but I get an error.
        from m5stack import *
        from m5ui import *
        from uiflow import *
        setScreenColor(0x111111)
        print(APIKEY)
        "_APIKEY" also resulted in an error.
        Do I need to install any additional modules?
        • IAMLIUBOI
          IAMLIUBO
          Try:
          import deviceCfg
          print("APIKEY: " + deviceCfg.get_apikey())
          But the APIKEY not fixed.I think you should use MAC addr for the devices:
          import machine
          import binascii
          mac_addr = binascii.hexlify(machine.unique_id()).decode('utf-8')
          • U
            utaani @IAMLIUBO
            @iamliubo, Thanks for reply!
            By using this code, I was able to get the API Key:
            import deviceCfg
            akey=deviceCfg.get_apikey()
            BTW, the MAC address can be obtained with the following code:
            macaddr=wifiCfg.wlan_sta.config('mac')
            macaddr='{:02x}:{:02x}:{:02x}:{:02x}:{:02x}:{:02x}'.format(*macaddr)
            Thank you!
            • L
              labixiaoxin8888
              Hello, how about accessing the device's API key from Blockly? Is it possible? I am using M5 Stack new Stamp Pico.
                ajb2k3 @labixiaoxin8888
                @labixiaoxin8888 No need as the API key is stuck on the front of the stamp.
                If you install Thonny and run the terminal monitor, the API's for any device connected will be shown in the terminal for Micropython.
                • L
                  labixiaoxin8888 @ajb2k3
                  @ajb2k3 Alright, thank you!
                  • L
                    labixiaoxin8888
                    @ajb2k3 Is it possible to print any output for UI flow remote control website?
                      There is an experimental feature of Micropython called webRPEL
                      • L
                        @ajb2k3 Thanks!
