Com.X.LoraWan 868 module configured at 470Mhz ?
HI All,
just bought the module COM.LoRaWAN 868 and I'm trying to configuring as Lora to test communication with a different module i got.
When i try to configure the frequency, I got error "+ERROR: the command is not supported"
I'm trying with:- ATCommand("FREQ", "868000000");
- ATCommand("LoraPara", "868000000,18,12,0,1,8,1,0,0");
and I get the same error.
Then I tried to inquire about current setting and I get on reset::
16:21:56.550 -> AT Rev 1.3
16:21:56.550 -> +AutoLPM=0
16:21:56.550 ->
16:21:56.550 -> +LORAWAN=0
16:21:56.550 ->
16:21:56.550 -> +FREQ=470000000
16:21:56.550 -> +TxPower=10
16:21:56.550 -> +SF=7
16:21:56.550 -> +BW=0
16:21:56.550 -> +Coderate=1
16:21:56.550 -> +Preamblelth=8
16:21:56.550 -> +CRC=1
16:21:56.550 -> +IQInvert=0and by issuing " ATCommand("LoraSet", "?");"
16:21:59.708 -> +LoraPara:470000000,10,7,0,1,8,1,0If i check on the chip CubeCell, below the logo it show 863-870
Is there anything wrong on my module?
Hello @ecasti
no, I don't think there is anything wrong with your module. My two modules report the same firmware version 1.3 as yours and the same frequency (470000000) is returned when uninitialized. I also get the same error (not supported) when trying to set the frequency via
FREQ
. I think the documentation doesn't 100% match the firmware installed on the module.I am using below command to setup LoRa parameters for a point to point connection:
ATCommand("LoraSet", "868000000,18,12,0,1,8,1,0,0");
@felmue said in Com.X.LoraWan 868 module configured at 470Mhz ?:
LoraSet
Thanks a lot, Felix,
it works !
Will try to find more details about this firmware to drop some note here.
Happy New Year
Hello @ecasti
glad to hear you got it working and thank you for reporting back.
Happy New Year!
