    Digital-Input Modul 24V
    General
    7.3k
      mamtho
      Hi there,
      is there any existing Digital Input Module/unit which works with external 24V using something like optocoupler?
      It should have up to 16 digital IO extension, each with an separate optocoupler.
      So i can get 24V from any system like an Door closed Sensor.
      Each Door has his own 24V.
      It would be nice to extend this Inputs by combing more Moduls.
      An Grove Unit would be also good, which i can extend with an Hub.
      thx Thomas
      ArnoA 1 Reply Last reply Reply Quote 2
      • P
        pieter
        I have the same question. Did somebody find a simple solution for this?
        • ArnoA
          Arno @mamtho
          @mamtho
          Concerning the additional I/O I use the EXTEND I/O modules, Provide a PaHUB if you need to use several.
          https://shop.m5stack.com/products/official-extend-serial-i-o-unit?_pos=1&_sid=b8a3ee0de&_ss=r
          https://shop.m5stack.com/products/pahub-unit?_pos=3&_sid=007221827&_ss=r&variant=16804803412058
          For the inputs here is a solution with optocouplers:
          https://fr.aliexpress.com/item/4000590924896.html?gatewayAdapt=glo2fra&spm=a2g0o.9042311.0.0.27426c375yTe7T
          For outputs, I've used this before:
          https://fr.aliexpress.com/item/32649191991.html?gatewayAdapt=glo2fra&spm=a2g0o.cart.0.0.24bc3c00xAiFgs&mp=1
