    m5Paper Screen issue
    PRODUCTS
    m5paper screen
    6.8k
    • E
      ebr61168
      since 1 month i got a m5Paper and I just ran the factory Image and some UIFlow tests.
      Yesterday, after a few days i want to do some Arduino stuff with my m5Paper. I refreshed the screen and some lines are still there.
      See Pic: alt text
      I tried a complete refresh and changed the color to black and back to white.
      Those line are still persistent.
      Got somebody a similar issue?
        Hello @ebr61168
        what happens if you install UIFlow firmware onto your M5Paper again? Does the line go away?
        • E
          ebr61168
          No, the lines persist.
          Flashed the most recent uiFlow Image
            Hello @ebr61168
            have you tried to fully power off and restart your M5Paper? Do do so, disconnect USB, then press the reset / power off button in the back for a couple of seconds, then reconnect USB.
            Also, when you say the lines persist. Does the UIFlow screen appear on the paper display together with the lines? Or just the lines?
            • E
              ebr61168
              Hello felmue,
              the UIFlow screen appear on the paper display together with the lines.
              The screen is working fine except the persistent lines. The vertikal line got another color, it is more black and a bit shiny.
                Hello @ebr61168
                I am out of ideas at this point in time, sorry.
                Have you checked with M5Stack support or the shop / store you got your M5Paper from?
