    RFID and UHF-RFID
    Units
    6.2k
    • K
      kylebuttress
      I have both the RFID RC522 unit and UHF-RFID unit. I can easily configure the RC522 to read tags and cards and return the relevant tag id etc. However when I try with the UHF-RFID no information is returned.
      I'm not sure If need specific types of tags for the UHF-RFID.
      Any Pointers would be fantastic.
      regards
      Kyle
      • G
        gleon
        what controller are you using?
        • H
          holofloh
          UHF-RFID use a different frequency so a standard smart tag will not work.
          RFID RC522 (most common for smart tags): 13.56MHz
          UHF RFID (long range): 860 to 960 MHz
          There are even more RFID frequencies like 125kHz, 134kHz... depending on the application and the country where it will be used.
          • K
            kylebuttress
            thanks for the update this will help. I'm sure. I will find some tags in the higher range and test again
            thanks
            • K
              kylebuttress @gleon
              @gleon m5 core, m5stick and m5paper
