    M5Tough upload fails, can anyone help?
    PRODUCTS
    4.3k
    • G
      GordonD
      With Arduino 1.8.19
      Windows10
      Question
      Hi, can anyone please help with my uploading problem?
      I have used M5Core2 successfully and now have M5Tough.
      I have loaded the M5Tough library and
      selected the correct board, M5Stack-Tough.
      I have selected the correct port when the M5Stack-Tough is plugged in.
      When I compile and upload any examples for M5Tough I get the following error message after a successful compile:
      Sketch uses 835953 bytes (63%) of program storage space. Maximum is 1310720 bytes.
      Global variables use 40444 bytes (12%) of dynamic memory, leaving 287236 bytes for local variables. Maximum is 327680 bytes.
      C:\Users\Gordon\AppData\Local\Arduino15\packages\m5stack\tools\esptool_py\3.3.0/esptool.exe --chip esp32 --port COM7 --baud 921600 --before default_reset --after hard_reset write_flash {upload.erase_cmd} -z --flash_mode dio --flash_freq 80m --flash_size 16MB 0x1000 C:\Users\Gordon\AppData\Local\Temp\arduino_build_195087/Time.ino.bootloader.bin 0x8000 C:\Users\Gordon\AppData\Local\Temp\arduino_build_195087/Time.ino.partitions.bin 0xe000 C:\Users\Gordon\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\2.0.5/tools/partitions/boot_app0.bin 0x10000 C:\Users\Gordon\AppData\Local\Temp\arduino_build_195087/Time.ino.bin
      usage: esptool write_flash [-h] [--erase-all]
                                 [--flash_freq {keep,80m,60m,48m,40m,30m,26m,24m,20m,16m,15m,12m}]
                                 [--flash_mode {keep,qio,qout,dio,dout}]
                                 [--flash_size FLASH_SIZE]
                                 [--spi-connection SPI_CONNECTION] [--no-progress]
                                 [--verify] [--encrypt]
                                 [--encrypt-files <address> <filename> [<address> <filename> ...]]
                                 [--ignore-flash-encryption-efuse-setting]
                                 [--compress | --no-compress]
      esptool write_flash: error: argument <address> <filename>: Address "{upload.erase_cmd}" must be a number
      Any help to identify what is causing this error would be welcome.
      Thanks.
      • V
        veryalien
        Have a look here: esptool write_flash: error: argument : Address "{upload.erase_cmd}" must be a number
        • G
          GordonD
          Thank you.
          I hope M5 or espressif can fix this bug soon.
