    M5 Core2 and unit UHF-RFID are bugged in UIFlow (bytes index out of range)
    6 Posts 3 Posters 8.3k Views 1 Watching
      tinkerer
      The default testing code does not work, something seem to be wrong in "units/_uhf_rfid.py"
      Changing the region does not help.
      Removing the region just moves the error tot the automatiq freq hopping step.
      Can someone help me figure out how I can find and edit the units/_uhf_rfid.py on the Core2?
      Thanks in advance
        kylebuttress @tinkerer
        @tinkerer
        I'm using the same Unit with M5Paper and its working very well. I did get a similar error when I was first starting my project.
        I did eventually get it working with the following set up.
        uhf_rfid_0.set_region(uhf_rfid_0.REGIN_US)
        uhf_rfid_0.automatic_freq_hopping(0xFF)
        uhf_rfid_0.set_channel_freq(924.25)
        epc_bool = 0
        uhf_rfid_0.set_select_mode(0x01)
        and then start waiting for tags with
        def reader():
        temp = None
        count = None
        clean = None
        while True:
        count += 1
            # while not temp:
            temp = uhf_rfid_0.single_polling()
            if temp:
                # label10.setText(str(temp))
                print("-----")
                print(temp[0])
                print(temp[1])
                print("-----")
        this is on a separate thread and works quite well for my requirements.
        The other issue I had and not sure if it was because I did not read correctly however. it works with the following tags (UHF RFID Tag ISO18000-6C)
        Not sure if it helps, but I hope it offers some info thats of use.
        reagrds
        Kyle
        • Bat21B Offline
          Bat21
          Hello everyone,
          I have the same problem, I have Core2 and Aton Lite and it doesn't work on any.
          The labels are not, since I have the SDK for JRD 4035 and I see them all. The EPC comes out complete with all its characters.
          With IIFLOW I have only managed to read from the EPC 6 characters.
          In Arduino I have not been able to make the EPC read.
          I have worn € 300 and it is very disappointing.
          Sorry for my bad English
          Cheers
            tinkerer @kylebuttress
            @kylebuttress Would you be willing to share the full code, I applied the initialization, but I remain having the same error.
              @tinkerer I'll extract out what I do for the reading and send it though I will test on my core unit as well
              I'm off line tomorrow so give me a day to get back to you ok.
                @tinkerer
                I made a quick reader nothing special and this is on a Basic Core unit
                quick video showing it working
                https://youtu.be/qvtr6Vy-HwY
                The Tags I use are these ones
                Tag 1
                Tag 2
                make sure the port is correct otherwise the bytes out of range error pops up
                from m5stack import *
                from m5ui import *
                from uiflow import *
                import unit
                setScreenColor(0x222222)
                uhf_rfid_0 = unit.get(unit.UHF_RFID, unit.PORTA)
                epc_bool = 0
                label0 = M5TextBox(128, 59, "Tag #", lcd.FONT_Default, 0xFFFFFF, rotate=0)
                label1 = M5TextBox(22, 106, "waiting ... ", lcd.FONT_Default, 0xFFFFFF, rotate=0)
                while True:
                        # while not temp:
                        if temp:
                            print("-----")
                            print(temp[0])
                            print(temp[1])
                            print("-----")
                            label1.setText(temp[0])
                        wait(.5)
