    Object has no attribute - Error
    4 Posts 2 Posters 5.5k Views
    • RIDDSprojectsR Offline
      RIDDSprojects
      It's very simple. The steps I do:
      1. Add unit (+) in UIFlow
      2. Add DIGI-CLOCK, default setting (Port A)
        2b. OK
      3. Open tap 'Units (1)' (under 'Hardwares') > Digi Clock
      4. Get block 'digi_clock_0 init 12c address (0x30).
      5. Run
      Error: File "<string>", line 8, in <module>
      AttributeError: 'module' object has no attribute 'DIGI_CLOCK'
      1. Add other blocks; does not matter
      2. Grab another controller; makes no difference (also error).
      Controlling directly with I2C is possible:
      (remove unit)
      Tap 'Hardwares', I2C Master:
      Block 1: i2c0 Master portA freq 400000
      Block 2: i2c0 Set slave addr 0x30
      Block 3: i2c0 Write reg 0x4 one byte 0xFF
      Display result: 8. (and no error!)
      Who can help me or has an addition?
      ATOM LITE | ATOM MATRIX | CORE | CORE2 | STAMP-PICO | CORE.INK | PAPER V1.1
      RESEARCH | INNOVATION | DEVELOPMENT | DESIGN | SUSTAINABILITY
      and electronics
      Nederland
        Hello @RIDDSprojects
        is your M5Stack running the latest UiFlow firmware (v1.10.9)? You can install it with M5Burner v3.0.
          RIDDSprojects
          Dear Felix,
          You helped me a lot! I had already looked several times for a firmware update, but it got stuck at v1.9.8. Thanks for your tip to use M5Burner Version 3 - I used M5Burner Version 2.5.1 myself. Confusing, but now clear! With, now v1.11.0, it works well!
          Thank you! Also for your very quick response.
          and electronics
          Nederland
            you are very welcome. I am glad to read it works for you now. And thank you for reporting back.
            Best of luck with your projects.
