Object has no attribute - Error
 It's very simple. The steps I do: - Add unit (+) in UIFlow
- Add DIGI-CLOCK, default setting (Port A)
 2b. OK
- Open tap 'Units (1)' (under 'Hardwares') > Digi Clock
- Get block 'digi_clock_0 init 12c address (0x30).
- Run
 Error: File "<string>", line 8, in <module>
 AttributeError: 'module' object has no attribute 'DIGI_CLOCK'- Add other blocks; does not matter
- Grab another controller; makes no difference (also error).
 Controlling directly with I2C is possible:
 (remove unit)
 Tap 'Hardwares', I2C Master:
 Block 1: i2c0 Master portA freq 400000
 Block 2: i2c0 Set slave addr 0x30
 Block 3: i2c0 Write reg 0x4 one byte 0xFF
 Display result: 8. (and no error!)Who can help me or has an addition?
 Hello @RIDDSprojects is your M5Stack running the latest UiFlow firmware (v1.10.9)? You can install it with M5Burner v3.0. Thanks
 Dear Felix,
 You helped me a lot! I had already looked several times for a firmware update, but it got stuck at v1.9.8. Thanks for your tip to use M5Burner Version 3 - I used M5Burner Version 2.5.1 myself. Confusing, but now clear! With, now v1.11.0, it works well!
 Thank you! Also for your very quick response.
 Hello @RIDDSprojects you are very welcome. I am glad to read it works for you now. And thank you for reporting back. Best of luck with your projects. Thanks
