    Lesson 19. LED BAR + MIC. LightMusic
    Scheduled Pinned Locked Moved Lessons and Guides
    1 Posts 1 Posters 9.2k Views 1 Watching
    • DimiD Offline
      Dimi
      The purpose of this lesson
      Hi! Today we will learn how to light multi-color led panels (only in the fire M5), relying on the components of the frequency of the audio signal received from the built-in (only in M5 fire) microphone.
      Figure 1
      This lesson will teach you how to connect and use third-party libraries to work with fast Fourier transform (FFT) and LEDs SK6818.
      Short help
      Color music is an art form based on a person's ability to associate sound sensations with light perceptions; this phenomenon in neurology is called synesthesia. Light music as an art is a derivative of music and is an integral part of it. Its purpose is to reveal the essence of music through visual perception. The main purpose of light music as an art is to study the ability of a person to experience the sensations imposed by light images when accompanied by music.
      Music lovers have long noticed that musical instruments sound much louder and clearer in a well-lit room than in a darkened one. Therefore, when performing serious music, the light in the hall is usually not extinguished.
      For the first time the connection between hearing and vision was very convincingly shown by Russian physicist and Russian physiologist academician P. P. Lazarev.
      Details on Wiki: https://ru.wikipedia.org/wiki/Светомузыка
      List of components for the lesson
      • PC/MAC;
      • M5STACK FIRE;
      • USB-C cable from standard set.
      Let's start!
      Step 1. The installation for the library with Led work bar
      Go to the link library Led bar in the section Download and download an example of the library files (Fig. 2).
      Figure 2
      Next, extract the archive to a new folder sketch and delete the file demo1.ino (Fig. 3).
      Figure 3
      Step 2. Installing the FFT library
      Go to the link Arduino Library FFT in the section Download and download an example of the library files (Fig. 4).
      Figure 4
      In the extracted contents folder and Then copied C:\Users\USER_NAME\Documents\Arduino\libraries new name arduinoFFT is arduinoFFT-master (Fig. 5).
      https://pp.userapi.com/c851016/v851016266/3d841/sySeWj6WcW4.jpg
      Figure 5
      Great! With libraries all :)
      Step 3. Writing a sketch
      Create a new sketch in the Arduino development environment and save it in the folder where the library files from step 1 are located (Fig. 6).
      Figure 6
      Immediately connect the necessary libraries and create the necessary variables:
      #include <M5Stack.h>
      #include "arduinoFFT.h"
      #include "esp32_digital_led_lib.h"
      arduinoFFT FFT = arduinoFFT();
      #define SAMPLES 256 //Must be a power of 2
      #define SAMPLING_FREQUENCY 10000 //Hz, must be 10000 or less due to ADC conversion time. Determines maximum frequency that can be analysed by the FFT.
      #define amplitude 50
      unsigned int sampling_period_us;
      unsigned long microseconds;
      byte peak[] = {0,0,0,0,0,0,0};
      double vReal[SAMPLES];
      double vImag[SAMPLES];
      unsigned long newTime, oldTime;
      strand_t m_sLeds = {.rmtChannel = 0, .gpioNum = 15, .ledType = LED_WS2812B_V3, .brightLimit = 32, .numPixels = 10, .pixels = nullptr, ._stateVars = nullptr};
      For simplified access to the LED BAR, I suggest using the following function void ledBar (int R, int G, int B, int M). Where int R, int G, int B - brightness of RED, GREEN and BLUE - respectively (from 0 to 255); int M - mode: from 0 to 9 - led number, 10 - all LEDs from the left panel, 11 - all LEDs from the right panel, 12 - all LEDs.
      The LEDs are arranged clockwise (Fig. 7).
      Figure 7
      Figure 7.1
      void ledBar(int R, int G, int B, int M) {
        if ((M < 0) || (M > 13)) return;
        if (M == 11) // right
          for (int i = 0; i < 5; i++)
             m_sLeds.pixels[i] = pixelFromRGBW(R, G, B, 0);
        else if (M == 10) // left
          for (int i = 5; i < 10; i++)
        else if (M == 12) // all
          for (int i = 0; i < 10; i++)
        else
           m_sLeds.pixels[M] = pixelFromRGBW(R, G, B, 0);
        digitalLeds_updatePixels(&m_sLeds);
      Main part. Do not forget about void dacWrite(25, 0); that the speaker does not make strange sounds and cod.
      void setup(){
        pinMode(25, OUTPUT);
        pinMode(34, INPUT);
        sampling_period_us = round(1000000 * (1.0 / SAMPLING_FREQUENCY));
        pinMode(15, OUTPUT);
        digitalWrite (15, LOW);
        if (digitalLeds_initStrands(&m_sLeds, 1)) {
          Serial.println("Can't init LED driver().");
        digitalLeds_resetPixels(&m_sLeds);
      Note that pinMode (34, INPUT) is the analog input to which the built-in microphone is connected (Fig. 8) through the amplifier, so set it to INPUT.
      Figure 8
        for (int i = 0; i < SAMPLES; i++) {
          newTime = micros() - oldTime;
          oldTime = newTime;
          vReal[i] = analogRead(34); // A conversion takes about 1mS on an ESP8266
          vImag[i] = 0;
          while (micros() < (newTime + sampling_period_us));  // do nothing to wait
        FFT.Windowing(vReal, SAMPLES, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
        FFT.Compute(vReal, vImag, SAMPLES, FFT_FORWARD);
        FFT.ComplexToMagnitude(vReal, vImag, SAMPLES);
        dacWrite(25, 0);
        for (int i = 2; i < (SAMPLES/2); i++){ // Don't use sample 0 and only first SAMPLES/2 are usable. Each array eleement represents a frequency and its value the amplitude.
          if (vReal[i] > 200) { // Add a crude noise filter, 4 x amplitude or more
            if (i<=5 )             displayBand(0,(int)vReal[i]/amplitude); // 125Hz
            if (i >5   && i<=12 )  displayBand(1,(int)vReal[i]/amplitude); // 250Hz
            if (i >12  && i<=32 )  displayBand(2,(int)vReal[i]/amplitude); // 500Hz
            if (i >32  && i<=62 )  displayBand(3,(int)vReal[i]/amplitude); // 1000Hz
            if (i >62  && i<=105 ) displayBand(4,(int)vReal[i]/amplitude); // 2000Hz
            if (i >105 && i<=120 ) displayBand(5,(int)vReal[i]/amplitude); // 4000Hz
            if (i >120 && i<=146 ) displayBand(6,(int)vReal[i]/amplitude); // 8000Hz
      Light the LEDs will be using the function void displayBand (int band, int dsize). Where band - frequency in the signal; dsize - number of frequency in the signal. You can safely experiment here and achieve the best flashes.
      void displayBand(int band, int dsize){
        if (band > 1) dsize += 100;
        if (dsize >= 150)
          ledBar(0, 0, 0, 12);
          if (band == 0)
            if (dsize >= 300)
              ledBar(255, 0, 0, 0);
              ledBar(255, 0, 0, 1);
          else if (band == 1)
            if (dsize >= 180)
              ledBar(255, 255, 0, 3);
              ledBar(255, 255, 0, 4);
          else if (band == 2)
            if (dsize >= 170)
              ledBar(0, 255, 0, 5);
              ledBar(0, 255, 0, 6);
          else
            ledBar(0, 0, 255, 8);
            ledBar(0, 0, 255, 9);
      Final step
      That's all :)
      Downloads
      • Library LED BAR (GitHub): https://github.com/MartyMacGyver/ESP32-Digital-RGB-LED-Drivers/tree/master/arduino-esp32/demo1
      • Arduino FFT library (GitHub): https://github.com/kosme/arduinoFFT
