    PaHub with Hall sensor
    4 Posts 2 Posters 4.9k Views
      Kivlow
      i cant connect Hall sensor A3144E to Pa.Hub 9548AP on my M5Stack Core 2.
      What is a solution to use it ??
      Regard Kamil
        PaHub or Port A Hub is for use with I2C devices.
        Hall Unit is a Pb Device aka Port B Device (the connector collar tell you what port it connect to) for the Hall sensor you need a PbHub.
          Kivlow
          Ok i try to connect this way :
          core 2 -> Pb.hub -> hall sensor
          and i cant in UiFlow to set the hall sensor to pb.hub i get only grove.
          See picture
          And another wired thing - when i use Pa.Hub with ENV III i get temp and humidity ok but pressure is -4826090,3. I cant get negativ pressure :>
          When i connect direct to core 2 i get right value.
            Kivlow
            Ehhhh
            Anotcher anomaly i use Pb.Hub and i connect wind speed meter to ch0 and Hall sensor to ch1.
            I use digitalRead from ch0 to read IO 1 for speed meter and digitaRead ch1 read IO 1 to read hall
            AND signal is mixed for both. I get readings from windspped meter when i use hall and hall reads inputs when i blow to windspeed meter. When i use both i get stupid info :/
