    2. Kivlow
    K
    • Continue chat with Kivlow
    • Start new chat with Kivlow
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Save
    Saving
    Kivlow
    @Kivlow
    Reputation
    7
    510
    Profile views
    Followers
    0
    Following
    Joined Last Online
    Kivlow Follow
    Posts made by Kivlow
    • m5stack tough with wind direction sensor rs485
      Hello i want to read rs485 wind direction sensor.
      How to get data from this sensor. Instruction is guery frame is on this page :
      https://wiki.dfrobot.com/SKU_SEN0482_RS485_Wind_Direction_Transmitter_V2
      but i dont know how to write and get answer in UIFlow :/
      Need help :> one week no clue how to get info
      posted in General
      K
      Kivlow
    • Pb.HUB with two digital read unit.
      Hello,
      I have core 2 and i use port A to connect PB.HUB.
      Then i connect to the Hub wind speed meter and hall unit.
      Hall to ch1 and wind speed meter to ch2
      I use uiflow with code in picture.
      So when i send this program to core 2 i get false readings. Its like i get read from both at the same time. when i delete one digital read second works fine.
      posted in UIFlow
      K
      Kivlow
    • RE: PaHub with Hall sensor
      Ehhhh
      Anotcher anomaly i use Pb.Hub and i connect wind speed meter to ch0 and Hall sensor to ch1.
      I use digitalRead from ch0 to read IO 1 for speed meter and digitaRead ch1 read IO 1 to read hall
      AND signal is mixed for both. I get readings from windspped meter when i use hall and hall reads inputs when i blow to windspeed meter. When i use both i get stupid info :/
      posted in Bug Report
      K
      Kivlow
      Ok i try to connect this way :
      core 2 -> Pb.hub -> hall sensor
      and i cant in UiFlow to set the hall sensor to pb.hub i get only grove.
      See picture
      And another wired thing - when i use Pa.Hub with ENV III i get temp and humidity ok but pressure is -4826090,3. I cant get negativ pressure :>
      When i connect direct to core 2 i get right value.
      K
      Kivlow
    • RE: [Solved] Connecting 3 ENV units via 1 to 3 Hub to M5 Stack
      I use UIFlow
      i get weard readings like -482827.3 when connect to pa.hub but connected direct to core 2 ewerything is ok
      posted in General
      K
      Kivlow
      @m5stack said in [Solved] Connecting 3 ENV units via 1 to 3 Hub to M5 Stack:
      0x76
      Hello,
      i get a problem with Pa.HUB i connected to it ENV.III. I get Temp and Hum ok but i get -482827.3 for pressure.
      What is wrong ??
      posted in General
      K
      Kivlow
    • PaHub with Hall sensor
      Hello,
      i cant connect Hall sensor A3144E to Pa.Hub 9548AP on my M5Stack Core 2.
      What is a solution to use it ??
      Regard Kamil
      K
      Kivlow
