    [Solved] "#include <M5Core2.h>" doesn't compile
    arduino
    8.1k
    • rh1972R
      rh1972
      My code has the following with empty setup and loop:
      When I verify, it terminates with this:
      c:\users\xxxxx xxxxx\appdata\local\arduino15\packages\m5stack\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\include\c++\8.4.0\bits\allocator.h:46:10: fatal error: bits/c++allocator.h: No such file or directory
      The file does exist in that location. File doesn't exist in this location, but exists in other directories.
      I'm compiling this on a Core 2, using this guide:
      https://docs.m5stack.com/en/quick_start/core2/arduino
      So, what am I doing wrong?
      • teastainT
        teastain @rh1972
        Hi!
        I verify this simple code no problem.
        Is this what you were talking about?
        -Terry
        • rh1972R
          rh1972
          Hi, thanks for the reply.
          While writing my reply, I realised I misread the error. Arduino IDE cannot find "bits/c++allocator.h" which indeed doesn't exist in this directory. It exists in multiple different directories, though.
          I coped "c++allocator.h" into the path stated in my original post, and it got over this error. But, it's now missing another file.
          I could copy all these missing files (assuming there's more), but something seems to be wrong here.
          • teastainT
            teastain @rh1972
            @rh1972 said in "#include <M5Core2.h>" doesn't compile:
            c++allocator.h
            My recent install of Arduino V2.0.3 doesn't have c++allocator.h installed and I could not find it anywhere in my computer.
            So, yes! I agree there must be something else wrong.
            Are you using Arduino V2.0.3?
            • rh1972R
              rh1972
              Yeah, I'm using v2.0.3
              I installed the "M5Stack" boards, and then the "M5Core2" libraries, including dependencies. I've tried different versions of the boards.
              I'm I missing something obvious?
              • rh1972R
                rh1972
                Well, it's working.
                The path to my Windows profile has a space in it. I created a local account without a space, and my empty program compiled with no issues. Don't know if that's the reason. Very strange.
                Makes me want to reinstall Ubuntu, or something.
                Thanks for the replies, Terry.
