    Warranty question M5stack is dead
    PRODUCTS
    15
    29.9k
    • I
      ispybadguys
      It doesn’t appear on the computer. It doesn’t power up with 2 different cables and 2 different USB supplies or when plugged in to the computer USB or on the internal battery.
      • I
        ispybadguys
        I plugged the M5Stack into a USB power source and measured the power pins with a DVM. The Battery pin measures 4.2V, the 3.3 volt pin measures 3.3 volts, and the 5V pin 5 volts. But the device does not power up.
        • I
          ispybadguys
          I tried some additional troubleshooting. I removed the bottom battery slice and plugged the top slice into my computer. There is no connection to the device so nothing can be uploaded. The display is also dark in this configuration and with it plugged into a USB charger.
          • I
            ispybadguys
            I seems that the problem resolved itself. This is very strange. I removed the battery slice several times but this did not resolve the problem. I even removed it once for at least a day. Finally I removed that battery slice and I let the unit sit for several days without the battery. When I reconnected the battery it started working link nothing ever happened.
            • m5-docsM
              m5-docs @ispybadguys
              @ispybadguys A Power supply problem, please contact to Hardware Engineer of M5Stack
              tech@m5stack.com
              M5Stack documentation URL
              https://docs.m5stack.com
              • KabronK
                Kabron
                I also have a question. I got M5Fire in M5Bala set.
                Half of USB-C does not work, i.e.: in one position PC does discover device, while in 180 degrees opposite - does not.
                Is it a kind of warranty case?
                I wrote to official M5Store seller on aliexpress, but got no answer.
                  ajb2k3 @Kabron
                  @kabron get a new lead, I get this with an expensive leads.
                  • KabronK
                    Kabron @ajb2k3
                    @ajb2k3 在 Warranty question M5stack is dead 中说:
                    You mean to try another cable? I tried all I have.
                      ajb2k3 @Kabron
                      @kabron I brought 4 different ones before I found one that works in any direction.
                      I ended up paying £20 for a lead and that only works if the usb C connector is in a certain rotation.
                      Yes I brought 4 leads spending over £30 just on leads!
                      • m5-docsM
                        m5-docs @Kabron
                        Hi, kabron @kabron Does your Type-C cables work now?
                        • KabronK
                          Kabron @m5-docs
                          @watson 在 Warranty question M5stack is dead 中说:
                          It works in only one direction(position).
                          • m5-docsM
                            m5-docs @Kabron
                            @kabron
                            Hi
                            You means that only one direction(positive) which USB-C cables inserted to PC, and PC will discover usable Serial Port.
                            If you turn USB-C cable around 180 degrees, the serial port will disappear.
                            Do I descripte your phenomenon correctly?
                            • KabronK
                              Kabron @m5-docs
                              Absolutelly correct.
                              I have to mark socket sides of all my cables
