    Goplus2 with M5Stack core -> Motor to slow
    9 Posts 4 Posters 9.9k Views 1 Watching
      TheAlphaGhost
      I have a issue with GoPlus2 and a RC Motor.
      If i use the motor on a raspberry with L298N Motor driver the speed ist very fast.
      On M5Stack core with GoPlus2 and Full Speed 100 (+127) the motor runs 1/3 of the speed from the L298N. What's the issue in M5 GoPlus2 ? Why the motor is too slow ?
      If i connect on the GoPlus2 a external battery with 7.4V it makes no difference.
      Has anyone a idea, how i can drive faster my dc motor with the GoPlus2 Modul ? It looks like the issue is "not" on motor or power voltage side. Must be on GoPlus2.
      • teastainT Offline
        teastain @TheAlphaGhost
        @thealphaghost The MotorWriteSpeed is an int, which could be at least 255.
        Could you try a number greater than +127 and see if this hack works?
        -Terry
          TheAlphaGhost
          Hi @teastain
          128 reverse the direction from forward to backward
          • teastainT Offline
            @thealphaghost OK! thanks for trying!
            Good luck!
              The voltage output from the go2 is only 5V
                TheAlphaGhost @ajb2k3
                WHAT? Really?!
                Then thats my problem! I cant find this information in the docs. It make no sense, if i can connect a external 12V Batterie…
                ajb2k3A teastainT 2 Replies Last reply Reply Quote 0
                  ajb2k3 @TheAlphaGhost
                  @thealphaghost when I tried running a 12v loco off a 12v battery I was only getting 5v out
                  • teastainT Offline
                    @thealphaghost You COULD connect the L298N using the GPIO on the side of the Core Basic?
                    Or if you NEED the GoPlus2 could you use three of the GroveB outputs?
                    • felmueF Online
                      Hello @TheAlphaGhost
                      have a look at the schematic here. Input voltage goes through the IN Power Buck DC-DC and the output is 5 V, which is used for servos and DC motors.
