    Modbus Master crashes and missing documentation
    6 Posts 3 Posters 5.9k Views
    • I Offline
      insaneLX
      I am trying to create a modbus master application in micropython. I cannot figure out how to use the write_single_coil register as I get a ValueError: Illegal coil value when using following line:
      modbus.write_single_coil(1,0, 1, timeout=500)
      Also, the documentation on Modbus is really flaky - can you point to some examples or maybe the source code of the implementation so I can look it up?
        Hello @insaneLX
        from earlier posts I assume you're trying with an M5Tough, correct?
        Well, I can confirm that write_single_coil fails with Value Error as soon as the value is different from 0.
        So, yes, I'd say it is broken. @m5stack could you please look into that. Thanks.
        BTW: other Modbus blocks like write_single_register work for me.
        • I Offline
          insaneLX
          Felix, thanks for the reply.
          I was trying to use the write_single_coil as workaround. I wanted to use the write multiple coils function. But it does not have a parameter to set the number of coils to be written and the documentation is less than complete. Any ideas? How does the system know what to write?
            Hello @insaneLX
            I think the multiple coils function takes a list, but it didn't work for me either.
            • I Offline
              insaneLX
              A list it is!
              try:
              ret = modbus.write_multiple_coils(comms.DEVICE_ADDRESS, 0,(
              sig.smoke_flap,
              sig.transport,
              sig.ignition,
              sig.smoke_fan,
              sig.extinguish,
              sig.flood,
              sig.ember_air,
              sig.alarm
              ), timeout=200)
              works nicely.
                pandian.nano
                Hi, @insaneLX 0_1688369025206_5545b634-1765-460d-a5c1-c3d1ae46fd74-image.png
                0xff00(ON or 1) and 0x00(OFF or 0)
