    How to connect SIM7020G to the network?
    PRODUCTS
    5
    8
    6.3k
    • J
      jeetS
      Hi there,
      I have SIM7020G COM.X NB-IOT module and I am trying to connect it with network.
      I am using 12V 3A SMPS and DC-DC step down converter (3A max) to drive SIM7020G module. Also, I am using airtel sim card.
      AT
      OK
      AT+CPIN?
      +CPIN: READY
      OK
      AT+CSTT="airtelgprs.com,"",""
      ERROR
      AT+CSTT="airtelgprs.com","",""
      OK
      AT+
      +CGREG: 0â–’â–’CI
      +CGREG: 2
      +CGREG: 0
      AT+CIICR
      ERROR
      AT+CGREG=?
      +CGREG: (0-2)
      OK
      AT+CSQ
      +CSQ: 99,99
      OK
      +CGREG: 2
      This is what I am getting in response and I tried to change sim card.
      Thank you so much in advance
      • A
        ameero95
        @jeets said in How to connect SIM7020G to the network?:
        airtel sim card
        does your sim card provider's network provider/s support NB-IoT? Because the SIM7020G only supports NB-IoT.
        • H
          HappyUser
          You may also try to remove the simlock of your card.
            Hello @HappyUser
            as far as I understand below AT command and response from the log means that the SIM card is unlocked, no?
            AT+CPIN?
            +CPIN: READY
            OK
            • H
              HappyUser @felmue
              @felmue Indeed, According to the manual Ready means MT is not pending for any password.
              Regards
              Jitse
              • H
                HappyUser @jeetS
                @jeets +CSQ: 99,99 tells me that you don't have a signal.
                  silentrain23 @HappyUser
                  @HappyUser
                  I am struggling trying to make a M5CORE2 working with a COMX.NB.IOT module.
                  I am gettingAT+CSQ 99,99
                  AT+COPS 0
                  AT+CREG 0,2
                  Do you think I am communicating in the correct way with the module?
                  Any Idea on how to connect to the network?
                    felmue @silentrain23
                    Hello @silentrain23
                    I think you probably just need to wait a bit longer for it to register.
                    From the AT Command document (link here) the 2 in the AT+CREG 0,2 response means: Not registered, but MT is currently searching a new operator to register to
