    Can't register devices to an account
    Bug Report
    13.3k
    • C
      ciconde
      I have one new device and after upgrading firmware I don't see any option to register it to my account.
      I am successfully logged to both M5Burner and UI Flow web and I can connect to the device and download it, but I see no means of registering it to my device manager.
      Tried regenerating API Key, no luck with new one but still able to connect and download.
      Thanks!
        What device and What UIFlow Firmware ?
        It would appear that some are getting issues with the registration and need to email M5Stack.
        • C
          ciconde
          Core2 V1.12.2
          • C
            ciconde
            Also just happened with Atom Lite, also V1.12.2
            • C
              ciconde
              @ajb2k3 Register process is done with M5 Burner, isn't it?
                ajb2k3 @ciconde
                @ciconde yes when you erase and burn new firmware to the controller
                • C
                  ciconde
                  @ajb2k3 Just did exactly that: first erase, then burned the firmware.
                  M5Burner was logged in, but no dialog to bind the device:
                  Why there's no option nor dialog to bind? I'm using M5Burner latest version, just downloaded it...
                  I'd like to suggest a bind button on the UI to bind a successfully connected device, so this process would be even better.
                  Thanks!
                    Are you sure that you are burning UIFlow2 and not UIFlow?
                    UIFlow has a manual connection method.
                    https://studio.youtube.com/video/2K4hHGtskAU/edit
                    • C
                      ciconde
                      No, being regular M5stack Core2 and regular Atom Lite they are not S3 and therefore I can't burn UIFlow2. Am I wrong?
                      I can't recall the manual binding method for UIFlow, would you be so kind of clarifying this?
                      Long time ago, when I burnt my old devices the burner would ask me if I wanted to bind.
                      This is the only procedure I know.
                        mtylerjr
                        Core2 is one of the few (only?) platforms you can use with either, at the moment.
                        I know this because I burned Uiflow2 and Uiflow1 both, on my Core2 AWS, last Friday.
                        Uiflow1 is more complete at the moment, so that is what I am using for the next couple of weeks at least, until more stuff is added to Uiflow2, which is still in Alpha.
                          ajb2k3 @ciconde
                          @ciconde UIFlow 1 devices show an api code on the screen which has to be typed into UIFlow manually. UIFlow 2 devices don’t show this code and requests to bind during the firmware burning process
                          • C
                            ciconde
                            UIFlow 1 devices formerly had a way to add them to my user.
                            Not only they show in my Device Manager, they also refuse to be downloaded anonymously, which is great.
                            I don't find how to do it anymore.
                            Please mind all this issue is around binding a device to an user, not how to bind them to the programming tool, which is OK with API KEY.
                            • C
                              ciconde
                              @ajb2k3 Any comments on how to add my devices to this "M5Stack Device Platform - Beta"?
                                ajb2k3 @ciconde
                                @ciconde said in Can't register devices to an account:
                                UIFl0w2?
                                You need to log into M5Burner with your forum details and when you erase and burn UIFLOW2 firmware you will be asked to register device to your account
