    m5tough UIFlow2.0 Alpha 24. mqtt. first-timer needs some guidance
    UiFlow 2.0
    4.3k
      Maasi
      hi all,
      this is all very new to me so please bear with me.
      I want to use the m5 stack on my sailboat as a display for my rudder pos and depth. Both values are being published over mqtt via node red.
      When i run this uiflow everything works fine and the mqtt values are being displayed on the device. But when i press download to the device i get an error:
      traceback (most recent call last: file "main.py" line 69, in <module>
      file "main.py"line 52, setup
      file "umqtt/simple.py", line 68, in connect
      0SError: [Errno 118] EH0STUNREACH.
      what am i doing wrong ? :)
      Many thanks for any advice.
      import os, sys, io
      import M5
      from M5 import *
      from umqtt import *
      label0 = None
      label2 = None
      label1 = None
      triangle0 = None
      title0 = None
      mqtt_client = None
      def mqtt_SEATALK_DIEPTE_event(data):
      global label0, label2, label1, triangle0, title0, mqtt_client
      label0.setColor(0xffffff, 0x000000)
      label0.setText(str((str(((data[1]).decode())) + str('M'))))
      label0.setFont(Widgets.FONTS.DejaVu72)
      label0.setSize(1.4)
      def mqtt_SEATALK_ROER_event(data):
      label1.setColor(0xffffff, 0x000000)
      label1.setText(str((data[1]).decode()))
      label1.setSize(1.4)
      label1.setFont(Widgets.FONTS.DejaVu72)
      def mqtt_SEATALK_ROERICON_event(data):
      label2.setColor(0xffffff, 0x000000)
      label2.setText(str((data[1]).decode()))
      label2.setSize(1.4)
      label2.setFont(Widgets.FONTS.DejaVu72)
      def setup():
      M5.begin()
      Widgets.fillScreen(0x222222)
      label0 = Widgets.Label("Text", 9, 142, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
      label2 = Widgets.Label("Text", 147, 33, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
      label1 = Widgets.Label("Text", 10, 33, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
      triangle0 = Widgets.Triangle(1729, 485, 1699, 515, 1759, 515, 0xffffff, 0xffffff)
      title0 = Widgets.Title("Title", 3, 0xFFFFFF, 0x0000FF, Widgets.FONTS.DejaVu18)
      mqtt_client = MQTTClient('M5MFD', '192.168.1.111', port=1883, user='', password='', keepalive=0)
      Widgets.setBrightness(255)
      mqtt_client.connect(clean_session=True)
      mqtt_client.subscribe('SEATALK/DIEPTE', mqtt_SEATALK_DIEPTE_event, qos=0)
      mqtt_client.subscribe('SEATALK/ROER', mqtt_SEATALK_ROER_event, qos=0)
      mqtt_client.subscribe('SEATALK/ROERICON', mqtt_SEATALK_ROERICON_event, qos=0)
      Widgets.fillScreen(0x000000)
      title0.setColor(text_c=0xffffff, bg_c=0x333333)
      title0.setText('DEPTH & RUDDER')
      def loop():
      M5.update()
      mqtt_client.wait_msg()
      if name == 'main':
      try:
      setup()
      while True:
      loop()
      try:
      print_error_msg(e)
      except ImportError:
        You need a Wifi network for the data to be shared.When you test, devices are already connected to a network but when you download, you need to set a network for devices to use.
          Maasi @ajb2k3
          @ajb2k3 thanks for explaining, simply adding WLAN STA connect to SSID results in a Internal wifi error.. setting the wifi via the webburner isn't helping either. example as cheatsheet would be helpfull.
            You need two devices, one set as AP and one as STA for it to work.
            What error are you getting when set to STA?
            • J
              jamesmilleree
              Thanks for explaining.
