    Unable to verify flash chip connection
    5.3k
    • H
      hidarrin
      Hi, everyone. I'm getting the following when I try to upload a sketch to my m5Stack Core Basic:
      Sketch uses 230493 bytes (17%) of program storage space. Maximum is 1310720 bytes.
      Global variables use 20968 bytes (6%) of dynamic memory, leaving 306712 bytes for local variables. Maximum is 327680 bytes.
      esptool.py v4.5.1
      Serial port /dev/cu.usbserial-556E0263581
      Connecting.....
      Chip is ESP32-D0WDQ6-V3 (revision v3.0)
      Crystal is 40MHz
      MAC: b0:b2:1c:51:83:80
      Uploading stub...
      Running stub...
      Stub running...
      Changing baud rate to 921600
      Changed.
      A fatal error occurred: Unable to verify flash chip connection (Invalid head of packet (0xE0): Possible serial noise or corruption.).
      Failed uploading: uploading error: exit status 2
      I searched this forum for this, and I'm not optimistic this will be an easy fix, since I don't see anyone else running into this.
      This is just a blank sketch.
      Any thoughts on how to get around this? I'm on a Mac. Thanks!
      • teastainT
        teastain @hidarrin
        @hidarrin Might try a slower upload speed or a better cable.
        What sketch is currently running in the Core, right now?
        A blank sketch needs a delay, at least 100ms in the Loop or ideally a Serial print statement to test that the upload was in fact successful with the serial monitor.
        • H
          hidarrin @teastain
          @teastain Thanks for the reply.
          I've tried multiple cables. Some high-end ones. No change.
          The default sketch that ships on the Core was giving me this error, so I wiped with esptool, and same error.
          How do I slow the upload speed?
          Thanks again.
          • H
            hidarrin
            SOLVED:
            I found the upload speed setting, and sure enough, that fixed it. Thanks!
            • H
              hacxx Banned
              Try lowering the baud rate to 115200 in the upload settings—921600 can sometimes cause issues, especially on macOS. Also, double-check your USB cable (some are power-only), and try a different USB port or hub. If you're using a USB-C to serial adapter, that might be causing noise.
