    UiFLow2 M5Dial and IOEXT2
    UiFlow 2.0
    3.7k
    • H
      HorstdieWurst
      I am not able to get the IOEXT2 work with the M5Dial. Is this still not possible because of the Alpha 0-29?
      Anyone any idea? I also trried to make it work with Core2 and UIFlow1.9.5 but ioext2 is not listed here.
        Hello @HorstdieWurst
        in UIFlow2 alpha-29 M5Dial and EXT.IO2 works for me. I quickly tested input and output.
        Can you be more specific as to what exactly doesn't work for you? Maybe share the UIFlow blocks you've tired?
        As for UIFlow1 - the latest version is UIFlow 1.13.0 (which offers EXT.IO2).
        • H
          HorstdieWurst
          Te first one is ok and gives no error. The second picture gives an error 19 enddev. I have got no clue what to do.
            ok, I see. It looks like the count do loop fires of the i2c commands too quickly. I can make it work by adding a sleep 1 milliseconds block after the set servo pulse block.
            • H
              HorstdieWurst
              No the problem appears already when I set pin0 to servo or any thing else. Am I missing smething about the i2c setup?
              Maybe you could show me a basic setup for a pin to send a pulse to pin 0 or something like this. Maybe my ioext2 is broken?
                make sure the EXT.IO2 unit is connected to the red Groove port of M5Dial. I get the error you mentioned if I disconnect the unit.
                Below are the blocks that work for me.
                Note: there is a typo in M5Dial firmware - it expects write_servo_pluse() instead of write_servo_pulse(). Therefore you cannot use the prepared block (until UIFlow firmware is fixed). Instead an Execute mpy code block can help out. PR to fix typo created.
                • H
                  HorstdieWurst
                  Ok this is what I tried and I got the error message. So I guess the my extio2 is broken. I will try to get a new a and try it again. Thank you uo to here ;)
                  Is it possible to send a normal 8 bit, 12 bit or best would be a 16 bit PWM to the i/os? Maybe with a mpy code? There is just the RGB mode which I do not understand, how they send 3x8bit on one i/o.
                  • H
                    HorstdieWurst
                    I got a new extio2 today and it works straight away. Many thanks for your help.
                    Can anyone tell me whether I can generate a 10, 12 or 16 bit PWM signal?
