    m5stack cardputer doesn't turn on.
    26 Posts 10 Posters 34.1k Views
      COZMIKDX
      Could be a bad USB-C cable. I had to switch mine out for the same reason.
      Or maybe your cable isn't pushed into the Cardputer or PC all the way.
      Make sure you're holding the G0 button and the power switch is off when you plug it in.
      Mine gave me no indication that it was ready to write to or turned on when I was in the same situation.
      • Sl4sh00S Offline
        Sl4sh00 @ajb2k3
        @ajb2k3 in my notebook. No, I just tried installing an app to see how it works.
        • Sl4sh00S Offline
          Sl4sh00
          Is there any way I can reset it so it turns back on?
            ajb2k3 @teastain
            @teastain Yeh, from my research it seams the issue lies with the Ch9120 chip and drivers.
            What I have found out is that the CH9120 (or whatever the number is) exposes two port the default port used for programming and a CDC port or boot loader port which is used for installing the low level boot loader used for UF2 to turn these devices into USB drives. On Raspbian/Linux I don't believe the CDC driver is installed and so preventing the low level Bootloader access hence the lack of green LED indicator working) on don't have a windows 11 PC to test so cant solve this issue but yet OSX works fine.
            You mentioned you had had other S3 based devices do they exhibit the same bad behaviour?
              Hello @ajb2k3
              just to clarify: the M5StampS3 (used in M5Cardputer) doesn't have an CH9120. The ESP32S3 has USB built-in using GPIO19/20. But it is correct that the built-in USB exposes multiple ports and functionalities. See here.
                I read that the internal adapter (on die) is based on the CH9120 chip (hence the need for the driver)
                Thanks for the pointer as it did show the issue 0_1706954335417_Screenshot 2024-02-03 at 09.58.11.png
                During default Programming mode the S3's go into Serial JTAG/OTG mode which blocks the Serial port with firmwares but the button press override and drops it into SPI mode.
                It would appear that these firmwares are blocking the SPI mode access.
                @felmue @teastain can you test the pins to see what they are doing when running these firmwares?
                • teastainT Offline
                  teastain @ajb2k3
                  @ajb2k3 Adam, very interesting. I will look into it.
                  My first S3 was the LilyGO T-Display S3, which took several weeks and the feeling that I had 'bricked' it by fumbling around. YouTuber Volos gave me insights to rein - in control.
                  I now have a LilyGO T-Display S3 AMOLED, extremely high resolution and clarity and and a large screen T-HMI, very well engineered, but not enough bit resolution for such a large screen.
                    Hello @ajb2k3
                    using M5Burner I've downloaded the below firmware to my M5Cardputer. Then measured G0, G1, G2 and G46 while the firmware was running.
                       NEMO for  | Marauder for | Cardputer | Volos Cardputer
                       Cardputer | Cardputer    | User Demo | TV Remote
                       v2.4.1    | v0.13.6      | v0.9.1    | v1.0
                    G0   3.3 V   |  3.3 V       |  3.3 V    |  3.3 V
                    G1   3.3 V   |  3.3 V       |  3.3 V    |  3.3 V
                    G2   3.3 V   |  3.3 V       |  3.3 V    |  3.3 V
                    G46  3.3 V   |  0 V         |  0 V      |  3.3 V
                    Note: Downloading firmware from M5Burner always put the M5StampS3 into download mode automatically - at no point did I have to manually set it to download mode using G0 button.
                    Note: I am on Ubuntu 20.04
                    teastainT Sl4sh00S 2 Replies Last reply Reply Quote 0
                      ajb2k3 @teastain
                      @teastain I thought you was Volos for a while
                      @felmue Thanks, It looks like that Serial/JTAG is the default mode unless USB OTG is set.
                      Thats what I though, Nemo and Marauda are pulling G0 high
                      • teastainT Offline
                        teastain @felmue
                        @felmue You are thorough.
                        • Sl4sh00S Offline
                          Sl4sh00 @felmue
                          @felmue said in m5stack cardputer doesn't turn on.:
                          Hello @ajb2k3
                          • teastainT Offline
                            teastain @Sl4sh00
                            @sl4sh00 Yes.
                            What app did you try to install?
                            That could be the root of the problem.
                            The BootLoader firmware is unbreakable, so there is no real problem.
                            Sl4sh00S 1 Reply Last reply Reply Quote 0
                            • robskiR Offline
                              robski
                              @Sl4sh00 can you try this...press and hold boot button (on side of cardputer or top of stamp) while holding connect usb then let button go, then try to load fresh firmware in M5Burner.
                              • Sl4sh00S Offline
                                Sl4sh00 @teastain
                                @teastain marauder
                                • Sl4sh00S Offline
                                  Sl4sh00 @robski
                                  @robski I tried holding down the reset button but nothing happened, is there any other way to install the firmware?
                                  • teastainT Offline
                                    teastain @Sl4sh00
                                    @sl4sh00 To put it into 'download' mode you can do as @robski suggested or:
                                    Press and hold the G0 Boot button...while holding it in, press and release the reset button, THEN release the G0 Boot.
                                    While doing this you can check the connection status in whatever burner app you are using.
                                    Please tell us if you can see the connection status AT ALL, this would be helpful in solving your problem.
                                    Sl4sh00S T D 3 Replies Last reply Reply Quote 2
                                    • Sl4sh00S Offline
                                      Sl4sh00 @teastain
                                      @teastain Thank you my brother, it works just like you said. Now it works again.
                                      • teastainT Offline
                                        teastain @Sl4sh00
                                        @sl4sh00 Thank you for getting back to us!
                                        • W Offline
                                          willyam @teastain
                                          @teastain bro thank u so mutch i tried it the whole day but nothing helped thank u so mutch , God bless you
                                            twinturbo @teastain
                                            @teastain i tried the same for my cardputer but no luck
