    Arduino IDE 2.3.2 M5Stamp C3, M5Unified ping time out
    6 Posts 3 Posters 4.0k Views
      HappyUser
      M5Unified 0.1.13 installed. Empty sketch. Takes long time to compile and then ping time out by the compiler.
      Any idea?
      #include <M5Unified.h>
      // put your setup code here, to run once:
      // put your main code here, to run repeatedly:
      • teastainT Offline
        teastain @HappyUser
        @happyuser Perhaps the sketch is 'too' empty.
        You should put a delay(100); in the Loop or it will jam up with too short cycle time.
        Is the Board Type in the Arduino IDE comm window 'M5StampC3'?
          HappyUser
          Thanks,
          Tried it also with a small sketch, same issue. I think it is related to the combination of M5StampC3 board and the M5Unified library.
          • teastainT Offline
            teastain @HappyUser
            @happyuser OK, the Stamp series (generally) don't need a library, just the code adjusted for their pinout and other specs.
            Try compiling and uploading without the unified library.
            Use serial print to test if code is running.
            -Terry
              HappyUser
              On GitHub it says :
              Supported devices (ESP32-C3)
              M5STAMPC3 / C3U
              I assume this refers to the Stamp C3 product. If so, it would be fair to assume that M5Unified is compatible with that device. It think the Arduino compiler has serious trouble compiling it.
                Hello @HappyUser
                it is correct that M5StampC3 is supported by M5Unified library, but I can confirm that the library currently doesn't compile due to errors in Mic_Class.cpp and Power_Class.cpp.
                I suspect that since there isn't much to gain from using a library like M5Unified for a stamp product (as @teastain already mentioned), M5Stack engineers aren't that alert in keeping the library updated.
