    Anyone using PlatformIO? Unable to get serial terminal to work.
    arduino
    4.1k
    • LukeSL
      LukeS
      Does anyone here use platform IO? I am unable to get the serial monitor to see what I print to the serial monitor. Anyone else have this issue?
      Main.cpp
      #include <Arduino.h>
      #include <M5Unified.h>
      int counter1 = 0;
        auto cfg = M5.config();
        M5.begin(cfg);
        delay(500);
        M5.Display.setTextSize(2);
        M5.update();
        M5.Display.setCursor(0, 20);
        M5.Display.print("C1: ");
        M5.Display.print(counter1);
        Serial.println(counter1);
        delay(200);
        counter1++;
      Platform.ini
      [env:m5stack-atoms3]
      platform = espressif32
      board = m5stack-atoms3
      framework = arduino
      monitor_speed = 115200
      monitor_rts = 0
      monitor_dtr = 0
      monitor_raw = yes
      lib_deps = m5stack/M5Unified@^0.1.13
      • teastainT
        teastain @LukeS
        @lukes In Arduino IDE you need to set the comm settings to USB CDC on Boot "Enabled", with S3 boards.
          Hello @LukeS
          please see this thread for a solution.
          • LukeSL
            LukeS
            Thanks guys adding the build flags fixed the blank serial terminal in PlatformIO.
