    [Product Revision] Tube/Air Pressure Unit with I2C
    Features Wish List
    6
    7
    3.8k
      Saiyande
      Tube/Air Pressure Unit (U130) with I2C output instead of analog (I2C Sensor or I2C ADC)
      1 Reply Last reply Reply Quote 8
        Maethaxi
        Adafruit makes one: https://www.adafruit.com/product/3965
        SparkFun also makes one: https://www.sparkfun.com/products/16476
        teastainT 1 Reply Last reply Reply Quote 2
        • teastainT
          teastain @Maethaxi
          @maethaxi Good info!
          The Adafruit must be an older design, as the I2C pins are not in the Grove signal order and would require cutting the end from a Grove cable and crossing wires and soldering!
          The Sparkfun unit is 'micro-grove' JST 1.0mm but wired correctly for grove. You would need a JST 2.0 (Grove) to JST 1.0 (qwiic) adapter cable. Mine is homemade but opens up another world of sensors to my faithful M5Stack equipment!
          added:
          Sparkfun qwiic to Grove converter cable
          https://www.sparkfun.com/products/15109
            Maethaxi @teastain
            @teastain
            Thanks for pointing out what the connectors are for M5Stack & SparkFun. I usually use "Grove2Dupont Conversion Cable 20cm (5Pairs)" (SKU: A096) for adapting stuff to grove. I'll add some JST PH (2.0) & JST SH (1.0) to my next components order.
            You're right, definitely opens up a whole new world of accessories!
            Z 1 Reply Last reply Reply Quote 0
            • Z
              Zavyru @Maethaxi
              @Maethaxi Adafruit has them as well: https://www.adafruit.com/product/4424
                Maecksu
                There's a similar request here:
                https://community.m5stack.com/topic/5241/new-module-sdp3x-differential-pressure-sensor
                • M Maecksu referenced this topic on
                • K
                  Kenzo @Maecksu
                  @Maethaxi Thanks I was looking for a Tube/Air Pressure unit with a I2C interface... I was trying to use the M5Stack Tube/Air Pressure Unit but I am running into an issue so I figured I would look for other options if I can't get it to work accurately... I need a sensor sensitive enough to detect someone blowing lightly in a tube....
