    ImportError: no module named 'M5' burned UIFlow2.0 - 2.0.5 with Fire
    UiFlow 2.0
    1.7k
    • T
      tech-dureco
      I do have probably basic question. I want to use UIFlow2.0
      I am getting error:
      I have used M5 burner and the latest is 2.0.5 for FIRE.
      I have selected correct device as well.
      Where I get "firmware" which includes correct modules?
      I do simply assume it is old FW as using UIFlow works. UIFlow does import M5stack UIFlow2.0 imports M5.
      Thank you for any help.
        Hello @tech-dureco
        hmm, burnt UIFlow v2.0.5 firmware onto my M5Stack Fire and then using UIFlow V2.0.5, selected USB Device: Fire and ran default program - no error.
        So I am not sure what went wrong on your side. Maybe try erasing your M5Stack Fire before installing UIFlow 2.0.5 firmware again?
          Make sure you erase and burn the correct firmware for the controller, UIFlow and uiflow2 are not the same
