    AtomS3 0.85" OLED unable to wake from buttom
    4 Posts 3 Posters 3.7k Views
    • N Offline
      notsonominal
      Recently tried using the AtomS3 with 0.85" OLED for a CAN-bus project and it seems like a missed opportunity to not have the (only) button under OLED connected to a pin that support waking up the ESP.
      Is there an easy workaround for this?
      I would also have to find a way to put the isolated CAN bus base to sleep to make this project viable with M5Stack products so I guess odds are I'll have to make my own, but I would be nice if new products were designed with deep sleep and power saving in mind.
      • teastainT Online
        teastain
        @notsonominal G41 is the input from the button into your program.
        You can read that button and do whatever your program needs, even transfer the input directly to an output.
        • N Offline
          notsonominal @teastain
          @teastain but G41 isnt supported as a wake-up pin from deep sleep - when the AtomS3 has a ton of free pins this seems like something that could be adressed in a future revision to make the product more usable.
            sonic
            I'm not able to get
            https://docs.m5stack.com/en/atom/Atomic CAN Base
            to work with the AtomS3, immediately TWAI_ALERT_ERR_PASS, TWAI_ALERT_BUS_ERROR
            https://docs.m5stack.com/en/unit/can
            works, though.
            What CAN library did you use? With what pin definitions?
            Thanks in advance!
