    Need help to build a parking sensor
    PRODUCTS
    • J
      JeyOne
      Hello, I´,m looking for two Ultrasonic sensors to be used as simple parking sensor (car under sensor yes/no is sufficient) to be integrated into home assistant. Preferred connection to Home Assistant via Wifi, power supply via USB power plug.
      I have more or less no technical knowledge in that area. looking for something like ESP32 for Home Assistant implementation.
      Can you recommend what I need, and do I need to solder anything? Do I need to install/use any complicated software other than home assistant?
      Thank you in advance
        ajb2k3 @JeyOne
        @JeyOne Please take a look at the examples in UIFLow's project zone.
        As to home assistant, I'm sure someone knows about HA.
