    ENV IV Unit not working with firmware V2.0.8
    UiFlow 2.0
    1.0k
    • D
      dcn91
      I did not succeed to make my ENV IV unit working with Firmware V2.0.8.
      Same issue with a M5Dial and a M5StickC
      The code (for StickC)
      import os, sys, io
      import M5
      from M5 import *
      from hardware import *
      from unit import ENVUnit
      label0 = None
      i2c0 = None
      env4_0 = None
      def setup():
        global label0, i2c0, env4_0
        M5.begin()
        label0 = Widgets.Label("label0", 4, 26, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
        i2c0 = I2C(0, scl=Pin(33), sda=Pin(32), freq=100000)
        print(i2c0.scan())
        env4_0 = ENVUnit(i2c=i2c0, type=4)
        label0.setText(str(env4_0.read_temperature()))
      def loop():
        M5.update()
      if __name__ == '__main__':
        try:
          setup()
          while True:
            loop()
          try:
            print_error_msg(e)
          except ImportError:
      The output :
      [68, 118]
      File "<stdin>", line 22, in <module>
      File "<stdin>", line 15, in setup
      File "unit/env.py", line 1, in init
      File "driver/bmp280.py", line 113, in init
      ValueError: device not found
      However, the 2 sensors are well detected during the I2C scan ( 68 is the SHT40, 118 is the BMP280).
      With Firmware V2.0.7, no issue for both devices.
        felmue @dcn91
        Hi @dcn91
        it's broken for me to. M5Dial UIFlow firmware v2.0.8. (And yes, with UIFlow firmware v2.0.7 it works fine.)
        Note: created an issue here.
        • felmueF felmue referenced this topic on
          mattjcuk
          I had this too and messaged M5stack, they said it is a bug since the new firmware 2.08 and they are fixing it.
          2.07 works fine with it.
          Thanks,
          Matthew
            felmue @mattjcuk
            Hi guys
            please try v2.0.9 which has the issue resolved.
