    Events during System-Time-Sleep
    UiFlow 2.0
    1.4k
      mattjcuk
      I'm using a M5Paper to take environmental readings, once I've updated the screen with all the readings, I using the System-Time-Sleep to wait 1 minute before I take more readings. It seems to pause the whole system so if I press any buttons during this 1 minute it doesn't seem to register this.
      Is there a way or a better command to only make the sensors take a reading every x minutes but also register any button presses during this wait period (it doesn't have to do anything but just register so once the x minute is up I can then do something based on the button press).
      Kind regards,
      Matthew
        felmue @mattjcuk
        Hello @mattjcuk
        you could use a timer instead which doesn't block other events like buttons.
        Please see Project Zone example: M5Paper_Timer_And_Button_UIFlow2.0.8
          mattjcuk @felmue
          Hi @felmue, perfect, that is exactly what I needed, thank you.
          Many thanks,
          Matthew
