    BMM150 doesn't work with M5AtomS3 and M5CoreS3
    Modules
    570
    • C
      carpenderspark
      I bought this one.
      6-DoF IMU Pro Mini Unit (BMI270, BMM150, BMP280)
      https://shop.m5stack.com/products/6-dof-imu-pro-mini-unit-bmi270-bmm150-bmp280
      Six-axis Attitude Sensor (BMI270) I2C address:0x68(default)
      Three-axis Geomagnetic Sensor (BMM150) I2C Address: 0x10
      Atmospheric Pressure Sensor (BMP280) I2C Address: 0x76
      I run I2C device probe program. The result is below.
      I get same result on M5AtomS3 and M5CoreS3.
      I use Visual Studio Code + PlatformIO.
      I2C Scan SDA:2 SCL:1
      68 .. .. .. .. .. .. ..
      .. .. .. .. .. .. 76 ..
      I also run on RaspberryPi. The result is below.
      raspi@raspberrypi:~ $ i2cdetect -y 1
           0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
      00:                         -- -- -- -- -- -- -- --
      10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
      70: -- -- -- -- -- -- 76 --
      Is this normal status ?
        auto cfg = M5.config();
        M5.begin(cfg);
        Wire.begin(M5.Ex_I2C.getSDA(), M5.Ex_I2C.getSCL(), 400000);
        Serial.printf("I2C Scan SDA:%d SCL:%d", M5.Ex_I2C.getSDA(), M5.Ex_I2C.getSCL());
        Serial.println();
        for (byte address = 0; address <= 127; address++) {
          byte error = Wire.endTransmission();
          if (error == 0) {
            Serial.printf("%02X ", address);
          } else {
            Serial.print(".. ");
            if (address % 8 == 7) {
              Serial.println();
          delay(1);
      Thank you.
        felmue @carpenderspark
        Hello @carpenderspark
        yes, that is normal. The reason is that the BMM150 is not directly connected to the I2C bus (e.g. SDA, SCL) but is behind BMI270 (e.g. BMM_SDA, BMM SCL). See schematic here. That is the reason it doesn't show up in the I2C scan.
        You can access it via BMI270 functions. See here.
        • C
          carpenderspark @felmue
          @felmue Wow, thank you. I saw schematic, I understand. I try. I will report the result.
          Thanks.
          • C
            carpenderspark @carpenderspark
            Umm, it doesn't seem good combination <M5Unified> and <M5Unit-IMU-Pro-Mini>.
            I got error message.
            Dependency Graph
            |-- M5Unified @ 0.1.16
            |-- VL53L1X @ 1.3.1+sha.8f21d60
            |-- M5Unit-ENV @ 1.0.1
            |-- M5Unit-IMU-Pro-Mini @ 1.0.2+sha.002b74a
            |-- WiFi @ 2.0.0
            Building in release mode
            Compiling .pio\build\m5stack-atoms3\src\main.cpp.o
            In file included from .pio/libdeps/m5stack-atoms3/M5Unit-IMU-Pro-Mini/src/M5_IMU_PRO.h:7,
                             from src/main.cpp:8:
            .pio/libdeps/m5stack-atoms3/M5Unit-IMU-Pro-Mini/src/BMI270.h:37:8: error: redefinition of 'struct BMI270::dev_info'
             struct dev_info {
            In file included from src/main.cpp:7:
            .pio/libdeps/m5stack-atoms3/M5Unit-IMU-Pro-Mini/src/BMI270.h:37:8: note: previous definition of 'struct BMI270::dev_info'
             struct dev_info {
            .pio/libdeps/m5stack-atoms3/M5Unit-IMU-Pro-Mini/src/BMI270.h:42:7: error: redefinition of 'class BMI270::BMI270'
             class BMI270 {
            .pio/libdeps/m5stack-atoms3/M5Unit-IMU-Pro-Mini/src/BMI270.h:42:7: note: previous definition of 'class BMI270::BMI270'
             class BMI270 {
            *** [.pio\build\m5stack-atoms3\src\main.cpp.o] Error 1
            M5Unified\src\utility\imu\BMI270_Class.hpp(11): class BMI270_Class : public IMU_Base
            M5Unit-IMU-Pro-Mini\src\BMI270.h(42): class BMI270 {
            I use this environment on PlatformIO.
            [env:m5stack-atoms3]
            platform = espressif32
            board = m5stack-atoms3
            framework = arduino
            lib_deps =
            	m5stack/M5Unified@^0.1.16
            	https://github.com/pololu/vl53l1x-arduino
            	m5stack/M5Unit-ENV@^1.0.1
            	https://github.com/m5stack/M5Unit-IMU-Pro-Mini
            It is better to change M5Unified to another baseic library, isn't it?
            • C
              AtomS3 has MPU6886. umm
              https://docs.m5stack.com/en/core/AtomS3
              Built-in 3-axis gyroscope and 3-axis accelerometer (MPU6886)
