BMM150 doesn't work with M5AtomS3 and M5CoreS3
I bought this one.
6-DoF IMU Pro Mini Unit (BMI270, BMM150, BMP280)
https://shop.m5stack.com/products/6-dof-imu-pro-mini-unit-bmi270-bmm150-bmp280
Six-axis Attitude Sensor (BMI270) I2C address:0x68(default)
Three-axis Geomagnetic Sensor (BMM150) I2C Address: 0x10
Atmospheric Pressure Sensor (BMP280) I2C Address: 0x76I run I2C device probe program. The result is below.
I get same result on M5AtomS3 and M5CoreS3.
I use Visual Studio Code + PlatformIO.I2C Scan SDA:2 SCL:1 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 68 .. .. .. .. .. .. .. .. .. .. .. .. .. 76 .. .. .. .. .. .. .. .. ..I also run on RaspberryPi. The result is below.
raspi@raspberrypi:~ $ i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- -- 70: -- -- -- -- -- -- 76 -- raspi@raspberrypi:~ $Is this normal status ?
auto cfg = M5.config(); M5.begin(cfg); Wire.begin(M5.Ex_I2C.getSDA(), M5.Ex_I2C.getSCL(), 400000); Serial.printf("I2C Scan SDA:%d SCL:%d", M5.Ex_I2C.getSDA(), M5.Ex_I2C.getSCL()); Serial.println(); for (byte address = 0; address <= 127; address++) { Wire.beginTransmission(address); byte error = Wire.endTransmission(); if (error == 0) { Serial.printf("%02X ", address); } else { Serial.print(".. "); if (address % 8 == 7) { Serial.println(); } } delay(1); }Thank you.
Hello @carpenderspark
yes, that is normal. The reason is that the BMM150 is not directly connected to the I2C bus (e.g. SDA, SCL) but is behind BMI270 (e.g. BMM_SDA, BMM SCL). See schematic here. That is the reason it doesn't show up in the I2C scan.
You can access it via BMI270 functions. See here.
Felix -
@felmue Wow, thank you. I saw schematic, I understand. I try. I will report the result.
Thanks. -
Umm, it doesn't seem good combination <M5Unified> and <M5Unit-IMU-Pro-Mini>.
I got error message.
Dependency Graph |-- M5Unified @ 0.1.16 |-- VL53L1X @ 1.3.1+sha.8f21d60 |-- M5Unit-ENV @ 1.0.1 |-- M5Unit-IMU-Pro-Mini @ 1.0.2+sha.002b74a |-- WiFi @ 2.0.0 Building in release mode Compiling .pio\build\m5stack-atoms3\src\main.cpp.o In file included from .pio/libdeps/m5stack-atoms3/M5Unit-IMU-Pro-Mini/src/M5_IMU_PRO.h:7, from src/main.cpp:8: .pio/libdeps/m5stack-atoms3/M5Unit-IMU-Pro-Mini/src/BMI270.h:37:8: error: redefinition of 'struct BMI270::dev_info' struct dev_info { ^~~~~~~~ In file included from src/main.cpp:7: .pio/libdeps/m5stack-atoms3/M5Unit-IMU-Pro-Mini/src/BMI270.h:37:8: note: previous definition of 'struct BMI270::dev_info' struct dev_info { ^~~~~~~~ In file included from .pio/libdeps/m5stack-atoms3/M5Unit-IMU-Pro-Mini/src/M5_IMU_PRO.h:7, from src/main.cpp:8: .pio/libdeps/m5stack-atoms3/M5Unit-IMU-Pro-Mini/src/BMI270.h:42:7: error: redefinition of 'class BMI270::BMI270' class BMI270 { ^~~~~~ In file included from src/main.cpp:7: .pio/libdeps/m5stack-atoms3/M5Unit-IMU-Pro-Mini/src/BMI270.h:42:7: note: previous definition of 'class BMI270::BMI270' class BMI270 { ^~~~~~ *** [.pio\build\m5stack-atoms3\src\main.cpp.o] Error 1M5Unified\src\utility\imu\BMI270_Class.hpp(11): class BMI270_Class : public IMU_Base
M5Unit-IMU-Pro-Mini\src\BMI270.h(42): class BMI270 {I use this environment on PlatformIO.
[env:m5stack-atoms3] platform = espressif32 board = m5stack-atoms3 framework = arduino lib_deps = m5stack/M5Unified@^0.1.16 https://github.com/pololu/vl53l1x-arduino m5stack/M5Unit-ENV@^1.0.1 https://github.com/m5stack/M5Unit-IMU-Pro-MiniIt is better to change M5Unified to another baseic library, isn't it?
AtomS3 has MPU6886. umm
https://docs.m5stack.com/en/core/AtomS3
Built-in 3-axis gyroscope and 3-axis accelerometer (MPU6886)
