    How to keep applications on M5 Core
    Lessons and Guides
    3.9k
    • C
      csierra67
      Hello everybody,
      Up to now I am using my Core in Internet mode, burning the device before every new download.
      I would like to save some of the programs on the device and use them in Application mode.. Is that possible with UI Flow ?
      Thanks for your suggestions
      csierra67
        ajb2k3 @csierra67
        @csierra67 yes you have to download them instead of running them to save them permanently
        • C
          csierra67 @ajb2k3
          @ajb2k3 Thanks but that's is exactly what I am doing.. I must be missing something !
          Right now on my Core, there are only two applications with the extension py that I can run in application mode. They came with the unit.. one is temp.py and the other one is RGB-Color-Pick.py
          No trace of my own applications..
          robskiR C 2 Replies Last reply Reply Quote 0
          • robskiR
            robski @csierra67
            @csierra67 install "thonny" its easy to see file structure
            M5StickC, M5StickCPlus, M5StickCplus2,M5GO, M5Core, M5Tough, M5Core2, M5 Demo Board, M5Dial, M5Paper, M5Atom, M5Cardputer, M5StampS3, CoreMP135, StamPLC, AirQ, M5Tab, M5CardputerAdv, M5Stack Chan
            • C
              csierra67 @csierra67
              @csierra67 Actually after having read my post.. I was able to put two applications on the device. The trick is NOT to burn after each change of application and to interrupt the automatic start of last downloaded application by hitting the application button..
              The "new" operating process opens new options.. so thanks for putting me on track
              • C
                csierra67
                @robski : some time ago I made some trials with Thonny but I was not really successful.. I will git it a new try.. at least for followng the remaining space, deleting the temp.py and so on
