    The image is not displayed
    20 Posts 10 Posters 15.1k Views
      ajb2k3 @iosapps420
      @iosapps420 I use GIMP for image editing.
      • I Offline
        iosapps420
        @ajb2k3 said in The image is not displayed:
        GIMP
        thank you, i'm going to download it, what settings do you use when you export the image/icon?
        thanks
          timothychenpc
          it seems like that the official converter(from jpg to .c code) does support JPEG, but not JPG
            mukul_100_
            Hi, even i am facing the same issue with uiflow 2, the image is in jpg and 100x100px
            please help.
              ajb2k3 @mukul_100_
              @mukul_100_ Try saving the file as jpeg not jpg
                mukul_100_ @ajb2k3
                @ajb2k3 hi thank you for the response
                i did try the suggested jpeg format with a 19kb file and it still shows no image but the default image label shows when no file is given to it
                can it be the image itself or uiflow 2?
                  mukul_100_ @mukul_100_
                  @mukul_100_ Has anyone got this working on a M5Dial? if they have i can check what actually is going wrong
                  • O Offline
                    Otis68 @mukul_100_
                    @I'm from Russia. and I apologize for my English. I am writing on this forum through a translator. I can't display a picture either. I work at UiFlow2 . I tried changing PNG formats to JPEG. There is no image. The image itself is 16*16pxl. I do my work with ATOM 3S.
                    mukul_100_
                    • N Offline
                      navatek
                      to view the images you have to upload them to the res/img folder in the upload window press the file button and select the res/img folder then the send file to here buttonCattura1.PNG Cattura2.PNG
                      • IAMLIUBOI Offline
                        IAMLIUBO
                        Hi all,
                        Thanks for report this, I think the main problem is the image format is not right, if you can provide the image to us, that's would be very nice.
                        have a nice day :)
                        BO
                        • N Offline
                          navatek @IAMLIUBO
                          @IAMLIUBO hi, i noticed that when you try to load the project in the device if you were to open the WebTerminal when you press the play button to try at the end the terminal writes the image error check height and width. I saw that in the device settings if you select it in the USB Device window, it gives you that error while if you select the device in the My Device window then it doesn't give any problems, so I think it's just a problem of understanding how to set UIFlow2
                          M 1 Reply Last reply Reply Quote 2
                            mukul_100_ @navatek
                            @navatek Hi, thanks a lot for the solution. finally it works and displays images normally
                            i was wondering if you have tried doing the same on arduino or other platforms.
                            • B Offline
                              brianoy @navatek
                              @navatek This works for me. You just save my day.
