    Settimino and M5 Paper, interacting weirdly
    4 Posts 2 Posters 2.5k Views
      kdshawee87
      Basically, M5Paper has a unique version of the I2C clock integrated into it. This version is causing conflicts with a Platform.h based program.
      The Error it keeps on pitching is that macro "min" requires 2 arguments, but only is presented with 1.
      the 8 bit integer could, technically, handle 60 minutes, however it wants "mm" not "m" in there. So i grabbed another RTC, and when i did , it broke everything. So i have to re-integrate the original I2C.h
      Any solution for this? I am trying to integrate this to step7. And it seemingly would work if there is a Serial Print function for M5Paper. I do not see that available, as it is actually "Canvas Draw" which leads to confusing integration.
      Any help would be great, my code is as follows:
      Data Read Demo
      Created 12 Dec 2016
      Modified 10 Mar 2019 for Settimino 2.0.0
      by Davide Nardella
      This demo shows how to read data from the PLC.
      A DB with at least 1024 byte into the PLC is needed.
      Specify its number into DBNum variable
      • Both small and large data transfer are performed (see DO_IT_SMALL)
      • During the loop, try to disconnect the ethernet cable.
        The system will report the error and will reconnect automatically
        when you re-plug the cable.
      • For safety, this demo doesn't write data into the PLC, try
        yourself to change ReadArea with WriteArea.
      • This demo uses ConnectTo() with Rack=0 and Slot=2 (S7300)
        • If you want to connect to S71200/S71500 change them to Rack=0, Slot=0.
        • If you want to connect to S7400 see your hardware configuration.
        • If you want to work with a LOGO 0BA7 or S7200 please refer to the
          documentation and change
          Client.ConnectTo(<IP>, <Rack>, <Slot>);
          with the couple
          Client.SetConnectionParams(<IP>, <LocalTSAP>, <Remote TSAP>);
          Client.Connect();
      #include <M5EPD.h>
      #include <Settimino.h>
      //Define Canvas Type
      M5EPD_Canvas canvas(&M5.EPD);
      // Uncomment next line to perform small and fast data access
      #define DO_IT_SMALL
      // Enter a MAC address and IP address for your controller below.
      // The IP address will be dependent on your local network:
      byte mac[] = {
      0x90, 0xA2, 0xDA, 0x0F, 0x08, 0xE1 };
      IPAddress Local(192,168,0,90); // Local Address
      IPAddress PLC(192,168,0,12); // PLC Address
      // Following constants are needed if you are connecting via WIFI
      // The ssid is the name of my WIFI network (the password obviously is wrong)
      char ssid[] = "SKYNET-AIR"; // Your network SSID (name)
      char pass[] = "yourpassword"; // Your network password (if any)
      IPAddress Gateway(192, 168, 0, 1);
      IPAddress Subnet(255, 255, 255, 0);
      int DBNum = 100; // This DB must be present in your PLC
      byte Buffer[1024];
      S7Client Client;
      unsigned long Elapsed; // To calc the execution time
      // Setup : Init Ethernet and Serial port
      M5.EPD.SetRotation(0);
      M5.EPD.Clear(true);
      M5.RTC.begin();
      canvas.createCanvas(960, 540);
      canvas.setTextSize(3);
      // Open serial communications and wait for port to open:
      Serial.begin(115200);
      #ifdef S7WIFI
      //--------------------------------------------- ESP8266 Initialization
      Serial.println();
      Serial.print("Connecting to ");
      Serial.println(ssid);
      WiFi.begin(ssid, pass);
      WiFi.config(Local, Gateway, Subnet);
      while (WiFi.status() != WL_CONNECTED)
      delay(500);
      Serial.print(".");
      Serial.println("");
      Serial.println("WiFi connected");
      Serial.print("Local IP address : ");
      Serial.println(WiFi.localIP());
      #else
      //--------------------------------Wired Ethernet Shield Initialization
      // Start the Ethernet Library
      EthernetInit(mac, Local);
      // Setup Time, someone said me to leave 2000 because some
      // rubbish compatible boards are a bit deaf.
      delay(2000);
      Serial.println("");
      Serial.println("Cable connected");
      Serial.println(Ethernet.localIP());
      #endif
      // Connects to the PLC
      bool Connect()
      int Result=Client.ConnectTo(PLC,
      0, // Rack (see the doc.)
      2); // Slot (see the doc.)
      Serial.print("Connecting to ");Serial.println(PLC);
      if (Result==0)
      Serial.print("Connected ! PDU Length = ");Serial.println(Client.GetPDULength());
      else
      Serial.println("Connection error");
      return Result==0;
      // Dumps a buffer (a very rough routine)
      void Dump(void *Buffer, int Length)
      int i, cnt=0;
      pbyte buf;
      if (Buffer!=NULL)
      buf = pbyte(Buffer);
      else
      buf = pbyte(&PDU.DATA[0]);
      Serial.print("[ Dumping ");Serial.print(Length);
      Serial.println(" bytes ]===========================");
      for (i=0; i<Length; i++)
      cnt++;
      if (buf[i]<0x10)
      Serial.print("0");
      Serial.print(buf[i], HEX);
      Serial.print(" ");
      if (cnt==16)
      cnt=0;
      Serial.println();
      Serial.println("===============================================");
      // Prints the Error number
      void CheckError(int ErrNo)
      Serial.print("Error No. 0x");
      Serial.println(ErrNo, HEX);
      // Checks if it's a Severe Error => we need to disconnect
      if (ErrNo & 0x00FF)
      Serial.println("SEVERE ERROR, disconnecting.");
      Client.Disconnect();
      // Profiling routines
      //void MarkTime()
      // Elapsed=millis();
      //void ShowTime()
      // Calcs the time
      //Elapsed=millis()-Elapsed;
      // Serial.print("Job time (ms) : ");
      // Serial.println(Elapsed);
      // Main Loop
      void loop()
      int Size, Result;
      void *Target;
      #ifdef DO_IT_SMALL
      Size=64;
      Target = NULL; // Uses the internal Buffer (PDU.DATA[])
      #else
      Size=1024;
      Target = &Buffer; // Uses a larger buffer
      #endif
      // Connection
      while (!Client.Connected)
      if (!Connect())
      delay(500);
      Serial.print("Reading ");Serial.print(Size);Serial.print(" bytes from DB");Serial.println(DBNum);
      // Get the current tick
      MarkTime();
      Result=Client.ReadArea(S7AreaDB, // We are requesting DB access
      DBNum, // DB Number
      0, // Start from byte N.0
      Size, // We need "Size" bytes
      Target); // Put them into our target (Buffer or PDU)
      if (Result==0)
      //ShowTime();
      Dump(Target, Size);
      else
      CheckError(Result);
      Result[3]="/0";
      M5.EPD.Clear(true);
      M5.RTC.begin();
      canvas.drawString((char*)Result, 0, 0);
      canvas.pushCanvas(0, 0, UPDATE_MODE_DU4);
      delay(500);
        kdshawee87
        kind-of answered my own question. Canvas Draw = Serial Print. So its just transposition or , well, commenting out. I chose commenting out for the time being. Target Not results.
          kdshawee87
          In file included from c:\Users\KSHAW47\Documents\Arduino\libraries\M5EPD\src/M5EPD.h:11,
          from C:\Users\KSHAW47\Documents\Arduino\ReadDemo_M5Paper\ReadDemo_M5Paper.ino:31:
          c:\Users\KSHAW47\Documents\Arduino\libraries\M5EPD\src/utility/BM8563.h:10:30: error: macro "min" requires 2 arguments, but only 1 given
          RTC_Time() : hour(), min(), sec() {
          c:\Users\KSHAW47\Documents\Arduino\libraries\M5EPD\src/utility/BM8563.h:12:60: error: macro "min" requires 2 arguments, but only 1 given
          RTC_Time(int8_t h, int8_t m, int8_t s) : hour(h), min(m), sec(s) {
          came back again, no known solution. please help
          namazu2024N 1 Reply Last reply Reply Quote 0
          • namazu2024N Offline
            namazu2024 @kdshawee87
            @kdshawee87
            Is there a possibility that it is conflicting with the Arduino macro?
            #define min(a,b) ((a)<(b)?(a):(b))
            This is a rough way of writing it, but in the header
            #include <M5EPD.h>
            #undef min
            Will it compile if I undef it?
            However, in this case, the standard min cannot be used in this file.
