Unit RELAY voltage
https://docs.m5stack.com/#/en/unit/relay
The picture shows 3A@220V, but the description says 120 VAC. So what voltage does the onboard relay actually support? I'm in the US, so I'm looking to use the Relay unit with a 120VAC. However, if the onboard relay only supports 220-240VAC, that won't work for me.
@world101 said in Unit RELAY voltage:
Well, if it supports 220-240V ac across the contacts @ 3A then 120V ac @ 3A is possible!
There are different versions suited for the voltage standards of different countries, please be sure to mention which one you want in the notes when ordering from our ali express shop -
@lukasmaximus
That’s what I needed to know. Thanks!
