    MQTT UIFlow problems
    UIFlow
    5
    19
    38.3k
    • H
      heybin
      Very sorry, we will fix it today,
      D world101W 2 Replies Last reply Reply Quote 0
      • D
        dvd78 @heybin
        @heybin thank you, this evening i will try...
        also, if i can, i think then the image used to insert text, label etc...in the m5 is too little
        • world101W
          world101 @heybin
          @heybin said in MQTT UIFlow problems:
          Has it been fixed yet? I'm trying the example, but after downloading the MQTT example flow to my m5stack Fire, it just freezes. It is not responsive until I reset it.
          https://m5stack.github.io/UIFlow_doc/cn/zh_CN/MQTT/Example.html
          My flow:
          cloudmqtt settings:
          Here are the logs from cloudmqtt.com. Not sure how to resolve the socket error.
          2019-01-22 19:07:18: mosquitto version 1.5.5 starting
          2019-01-22 19:07:18: Config loaded from /var/lib/mosquitto/19639/mosquitto.conf.
          2019-01-22 19:07:18: Opening ipv4 listen socket on port 29639.
          2019-01-22 19:07:18: Opening websockets listen socket on port 39639.
          2019-01-22 19:07:18: Opening ipv4 listen socket on port 19639.
          2019-01-22 19:09:09: New client connected from 64.100.78.39 as cloudmqtt-st-ui-0.9613626986254669 (c1, k60, u'oklhhzzb').
          2019-01-22 19:09:10: Socket error on client cloudmqtt-st-ui-0.9613626986254669, disconnecting.
          2019-01-22 19:09:11: New client connected from 64.100.78.39 as cloudmqtt-ws-ui-0.6445892594600325 (c1, k60, u'oklhhzzb').
          2019-01-22 19:10:05: Client cloudmqtt-ws-ui-0.6445892594600325 disconnected.
            What Operating system do you use?
            What M5 are you using?
              ajb2k3 @dvd78
              @dvd78 said in MQTT UIFlow problems:
              Use the internet browsers zoom function.
              • world101W
                world101 @ajb2k3
                @ajb2k3 said in MQTT UIFlow problems:
                I'm on a Mac with OS 10.13.6 (High Sierra).
                I have the m5stack Fire (red) hardware running v1.1.1.
                Is MQTT working for you?
                  ajb2k3 @world101
                  @world101
                  Yes, but I'm worried about the restarting.
                  I only have an M5Core
                  • world101W
                    world101 @ajb2k3
                    I have a m5stack grey as well that I will try tonight.
                    • D
                      dvd78
                      i have an M5core too but mqtt is not working yet
                        ajb2k3 @dvd78
                        @dvd78 Update firmware to 1.1.1 to get MQTT working.
                        • D
                          dvd78 @ajb2k3
                          i did it yesterday, do i need to download a new version?
                          • H
                            heybin
                            @dvd78 Sorry, yesterday our engineers forgot to update....
                            now, already fixed, refresh web page it will be ok
                            world101W D 2 Replies Last reply Reply Quote 0
                            • world101W
                              world101 @heybin
                              @heybin
                              MQTT working good for me now with both of my grey and fire m5stack cores. I have tested cloudmqtt and io.adafruit. Thanks for fixing it!
                              • D
                                dvd78 @heybin
                                @heybin thank you, problem is solved.
                                bye
                                • T
                                  The_Stacker
                                  I tried the same blocky today. It uploaded but on the display I only see: error ImportError('mqtt need download...'.)
                                  I am using an M5Stack Fire, firmware 1.1.2.
                                  I have a local MQTT broker running on an Onio Omega and the upload is done with a Windows 10 computer.
                                  Any help would be appreciated.
                                  • world101W
                                    world101 @The_Stacker
                                    @the_stacker
                                    Instead of running the program directly from uiFlow (which is the triangle button at the top-right), just click the Download option from the hamburger menu.
                                    • T
                                      The_Stacker
                                      Thanks! That worked.
                                      Just out of curiosity: What's the difference between the two?
                                      • world101W
                                        @the_stacker said in MQTT UIFlow problems:
                                        Run is just for quick testing of your program. It is erased on a reboot. Download will add the program to the flash storage on the device so you can access it from the APP.LIST menu (middle button when the M5stack is booting up - inbeteeen upload and setup).
