    M5 Unit Scroll Arduino Example
    9 Posts 3 Posters 6.5k Views
      cepics
      Hi All, I can't find an Arduino example about Unit Scroll.. I would like to implement selection and click...M5Unit-Scroll
      best regards
        cepics @cepics
        this code doesn't work
        #include <M5Atom.h>
        #include <M5UnitScroll.h>
        M5UnitScroll Scroll;
        int myVariable = 0;
        int previousEncoderValue = 0;
        bool buttonPressed = false;
          Serial.begin(115200);
          Scroll.begin(&Wire, 0x40, 26, 32);
          int currentEncoderValue = Scroll.getEncoderValue();
          int difference = currentEncoderValue - previousEncoderValue;
          myVariable += difference;
          previousEncoderValue = currentEncoderValue;
          if (Scroll.getButtonStatus()) {
            if (!buttonPressed) {
              myVariable = 0;
              buttonPressed = true;
          } else {
          Serial.print("myVariable ");
          Serial.println(myVariable);
          Serial.print("buttonPressed ");
          Serial.println(buttonPressed);
        some tips?
          HappyUser @cepics
          @cepics Have you checked whether M5UnitScroll.begin returns true? Baybe that gives a clue.
          Regards
            cepics @HappyUser
            @HappyUser I'm not sure how to check the begin function return value..
            I tried:
            #include <M5Atom.h>
            #include "M5UnitScroll.h"
            bool scrolla;
              Scroll.begin();
              scrolla = Scroll.begin();
              Serial.println(scrolla);
              delay(1000);
              scrolla = Scroll.begin(&Wire, SCROLL_ADDR, 32, 26);
              delay(1000);
              scrolla = Scroll.begin(&Wire, SCROLL_ADDR, 26, 32);
              delay(1000);
            and the output in the serial monitor is:
            10:56:20.024 -> 0
            10:56:21.044 -> 0
            10:56:22.062 -> 0
            10:56:23.084 -> 0
            10:56:24.071 -> 0
            10:56:25.092 -> 0
            10:56:26.081 -> 0
            10:56:27.102 -> 0
            10:56:28.129 -> 0
              cepics @cepics
              I tried an i2c scanner (not the atom one that doesn't work):
              #include <Wire.h>
              void setup()
                Wire.begin(26, 32);
                while (!Serial);             // Leonardo: wait for serial monitor
                Serial.println("\nI2C Scanner");
              void loop()
                byte error, address;
                int nDevices;
                Serial.println("Scanning...");
                nDevices = 0;
                for(address = 1; address < 127; address++ )
                  // The i2c_scanner uses the return value of
                  // the Write.endTransmisstion to see if
                  // a device did acknowledge to the address.
                  if (error == 0)
                    Serial.print("I2C device found at address 0x");
                    if (address<16)
                      Serial.print("0");
                    Serial.print(address,HEX);
                    Serial.println("  !");
                    nDevices++;
                  else if (error==4)
                    Serial.print("Unknown error at address 0x");
                    if (address<16)
                      Serial.print("0");
                    Serial.println(address,HEX);
                if (nDevices == 0)
                  Serial.println("No I2C devices found\n");
                else
                  Serial.println("done\n");
                delay(5000);           // wait 5 seconds for next scan
              and I can see 0x40
              next I tried to put in two tab the modified library M5UnitScroll.h (for scl end sda atom pin) and M5UnitScroll.cpp..
              M5UnitScroll.h
               * SPDX-FileCopyrightText: 2024 M5Stack Technology CO LTD
               * SPDX-License-Identifier: MIT
              #ifndef _M5UNITSCROLL_H_
              #define _M5UNITSCROLL_H_
              #include "Arduino.h"
              #include "Wire.h"
              #include "pins_arduino.h"
              #define SCROLL_ADDR            0x40
              #define ENCODER_REG             0x10
              #define BUTTON_REG             0x20
              #define RGB_LED_REG            0x30
              #define RESET_REG              0x40
              #define INC_ENCODER_REG         0x50
              #define BOOTLOADER_VERSION_REG 0xFC
              #define JUMP_TO_BOOTLOADER_REG 0xFD
              #define FIRMWARE_VERSION_REG   0xFE
              #define I2C_ADDRESS_REG        0xFF
              class M5UnitScroll {
                 private:
                  uint8_t _addr;
                  TwoWire* _wire;
                  uint8_t _scl;
                  uint8_t _sda;
                  uint32_t _speed;
                  void writeBytes(uint8_t addr, uint8_t reg, uint8_t* buffer, uint8_t length);
                  void readBytes(uint8_t addr, uint8_t reg, uint8_t* buffer, uint8_t length);
                 public:
                  bool begin(TwoWire* wire = &Wire, uint8_t addr = SCROLL_ADDR, uint8_t sda = 26, uint8_t scl = 32, uint32_t speed = 400000U);
                  int32_t getEncoderValue(void);
                  int32_t getIncEncoderValue(void);
                  bool getButtonStatus(void);
                  void setLEDColor(uint32_t color, uint8_t index = 0);
                  uint32_t getLEDColor(void);
                  void setEncoderValue(int32_t encoder);
                  void resetEncoder(void);
                  bool getDevStatus(void);
                  uint8_t getBootloaderVersion(void);
                  uint8_t getFirmwareVersion(void);
                  uint8_t setI2CAddress(uint8_t addr);
                  uint8_t getI2CAddress(void);
                  void jumpBootloader(void);
              #endif
              /*! @brief Initialize the Encoder. */
              bool M5UnitScroll::begin(TwoWire *wire, uint8_t addr, uint8_t sda, uint8_t scl, uint32_t speed) {
                  _wire  = wire;
                  _addr  = addr;
                  _sda   = sda;
                  _scl   = scl;
                  _speed = speed;
                  _wire->begin(_sda, _scl);
                  _wire->setClock(_speed);
                  delay(10);
                  _wire->beginTransmission(_addr);
                  uint8_t error = _wire->endTransmission();
                  if (error == 0) {
                      return true;
                  } else {
                      return false;
              /*! @brief Write a certain length of data to the specified register address. */
              void M5UnitScroll::writeBytes(uint8_t addr, uint8_t reg, uint8_t *buffer, uint8_t length) {
                  _wire->beginTransmission(addr);
                  _wire->write(reg);
                  for (int i = 0; i < length; i++) {
                      _wire->write(*(buffer + i));
              /*! @brief Read a certain length of data to the specified register address. */
              void M5UnitScroll::readBytes(uint8_t addr, uint8_t reg, uint8_t *buffer, uint8_t length) {
                  uint8_t index = 0;
                  _wire->write(reg);
                  _wire->endTransmission(false);
                  _wire->requestFrom(addr, length);
                      buffer[index++] = _wire->read();
              /*! @brief Read the encoder value.
                  @return The value of the encoder that was read */
              int32_t M5UnitScroll::getEncoderValue(void) {
                  int32_t value = 0;
                  readBytes(_addr, ENCODER_REG, (uint8_t *)&value, 4);
                  return value;
              /*! @brief Read the encoder inc value.
              int32_t M5UnitScroll::getIncEncoderValue(void) {
                  int32_t value = 0;
                  readBytes(_addr, INC_ENCODER_REG, (uint8_t *)&value, 4);
                  return value;
              /*! @brief Get the current status of the rotary encoder button.
                  @return true if the button was pressed, otherwise false. */
              bool M5UnitScroll::getButtonStatus(void) {
                  uint8_t data;
                  readBytes(_addr, BUTTON_REG, &data, 1);
                  return data == 0x00;
              /*! @brief Set the color of the LED (HEX). */
              void M5UnitScroll::setLEDColor(uint32_t color, uint8_t index) {
                  uint8_t data[4];
                  data[3] = color & 0xff;
                  data[2] = (color >> 8) & 0xff;
                  data[1] = (color >> 16) & 0xff;
                  data[0] = index;
                  writeBytes(_addr, RGB_LED_REG, data, 4);
              /*! @brief Get the color of the LED (HEX).
                  @return The value of the led that was read */
              uint32_t M5UnitScroll::getLEDColor(void) {
                  uint8_t data[4];
                  uint32_t value = 0;
                  readBytes(_addr, RGB_LED_REG, data, 4);
                  value = (data[3] | (data[2] << 8) | (data[1] << 16));
                  return value;
              void M5UnitScroll::setEncoderValue(int32_t encoder) {
                  writeBytes(_addr, ENCODER_REG, (uint8_t *)&encoder, 4);
              void M5UnitScroll::resetEncoder(void) {
                  uint8_t data = 1;
                  writeBytes(_addr, 0x40, &data, 1);
              /*! @brief Get the dev status.
                  @return 1 if the dev working, otherwise 0.. */
              bool M5UnitScroll::getDevStatus(void) {
                  if (_wire->endTransmission() == 0)
                      return true;
                  else
                      return false;
              uint8_t M5UnitScroll::getBootloaderVersion(void) {
                  _wire->write(BOOTLOADER_VERSION_REG);
                  uint8_t RegValue;
                  _wire->requestFrom(_addr, 1);
                  RegValue = _wire->read();
                  return RegValue;
              uint8_t M5UnitScroll::getFirmwareVersion(void) {
                  _wire->write(FIRMWARE_VERSION_REG);
                  uint8_t RegValue;
                  return RegValue;
              uint8_t M5UnitScroll::setI2CAddress(uint8_t addr) {
                  uint8_t temp[2] = {0};
                  temp[0] = I2C_ADDRESS_REG;
                  _wire->write(temp[0]);
                  _wire->write(addr);
                  _addr = addr;
                  return _addr;
              uint8_t M5UnitScroll::getI2CAddress(void) {
                  uint8_t RegValue;
                  return RegValue;
              void M5UnitScroll::jumpBootloader(void) {
                  uint8_t value = 1;
                  writeBytes(_addr, JUMP_TO_BOOTLOADER_REG, (uint8_t *)&value, 1);
              but this code outputs "error"
              #include <M5Atom.h>
              #include <Wire.h>
              // #include <M5UnitScroll.h>
              M5UnitScroll unitScroll;
                Wire.begin(26, 32);
                if (!unitScroll.begin()) {
                  Serial.println("Error");
                  while (1);
                unitScroll.setLEDColor(0x0000FF);
                int32_t encoderValue = unitScroll.getEncoderValue();
                Serial.print("Valore encoder: ");
                Serial.println(encoderValue);
                if (unitScroll.getButtonStatus()) {
                  Serial.println("Pulsante premuto!");
                  unitScroll.setLEDColor(0xFF0000);  // Red
                  delay(500);
                  unitScroll.setLEDColor(0x00FF00);  // Green
                  delay(500);
                delay(100);
                flypeek
                Connect the 4 wires on the back of g21 and g25, and modify the program code pin codeSnap6.jpg
                C 2 Replies Last reply Reply Quote 0
                  cepics @flypeek
                  @flypeek … means I can’t use atom grove port to connect to scroll unit?!?
                    cepics @flypeek
                    @flypeek this code, Atom g21 and g25 connected to the scroll grove port and library original pin assigment, works!!!
                    #include <M5Atom.h>
                      // if (!unitScroll.begin(&Wire, 0x40, 26, 32, 400000U)) {
                      // if (!unitScroll.begin(&Wire, 0x40, 32, 26, 400000U)) {
                        Serial.println("Errore nell'inizializzazione del sensore");
                        while (1);  // Ferma il programma in caso di errore
                      // LED
                        unitScroll.setLEDColor(0xFF0000);  // Rosso
                        delay(500);
                        unitScroll.setLEDColor(0x00FF00);  // Verde
                        delay(500);
                      delay(100);
                    but I need to connect the unit to the Atom grove port.... some tips??
                      cepics
                      EUREKA!!!!
                      With this setup it works
                        Wire.begin(26, 32);  // (sda, sck)
                        M5.begin(true, false, true);
