    How to use both 2 I2C interface on StickC-Plus2?
    PRODUCTS
    1.7k
    • 俺
      俺がガンダムだ
      Env PlatformIO
      platformio.ini:
      platform = espressif32
      board = m5stick-c
      framework = arduino
      lib_deps =
      	Wire
      	m5stack/M5Unified
      	m5stack/M5Unit-DDS
      Question:
      I connect 2 modules to StickC-Plus2, one on 'grove' port, the other on 'Ext.8-pin'. Is it correct to connect this way( or to say, is it possible to communicate with 2 modules through I2C separately through GPIO25-GPIO26 and GPIO32-GPIO33)? If this is correct, then how should I write the code?
      Currently in my code, I defined the second 'TwoWire' object and initialized a module with it, but communication failed, while default 'TwoWire(0)' works well.
      TwoWire I2C_DDS = TwoWire(1);
      	I2C_DDS.begin(DDS_SDA, DDS_SCL);
      	dds.begin(&I2C_DDS);
      • kurikoK
        kuriko
        @俺がガンダムだ
        Look at the definition of TwoWire, number should be fixed
