    Cardputer worked fine , but something happened on the screen and now a part of it is not displayed.
    FAQS
    8
    2.1k
      MiguelM
      ![alt text](![image url](displayProblem2.png image url))
      robskiR ajb2k3A 2 Replies Last reply Reply Quote 0
      • robskiR
        robski @MiguelM
        @MiguelM looks like rotation isnt right, what is displayed if you just burn easyLoader demo file or latest uiflow2 firmware from M5Burner?
        M5StickC, M5StickCPlus, M5StickCplus2,M5GO, M5Core, M5Tough, M5Core2, M5 Demo Board, M5Dial, M5Paper, M5Atom, M5Cardputer, M5StampS3, CoreMP135, StamPLC, AirQ
          ajb2k3 @MiguelM
          @MiguelM Looks like the wrong firmware has been burned.
            MiguelM @robski
            @robski thank for your help,
            I did the following:
            1. I loaded easyLoader demo and works fine. However if I l loaded in IDE Arduino (IDE 2.3.4 version) the behavior isn't correct, the screen does not fill correctly as the image indicates the issue.
            2. But strange... I have a second new card: I loaded the easyLoader demo (ok), I loaded the same Arduino source code and this second board works fine.
            Additionally, I bought the screen and the new M5stack board spare parts (M5stackS3 + display), but (1) cardputer it is not correct.
            it's very strange for me.
              MiguelM @ajb2k3
              @ajb2k3 the first card fails, the second card works fine.
              • X
                xhozt
                getting the same here on mine . reflash does not correct.
                • X
                  xhozt @xhozt
                  @xhozt also seems the IR blaster is borked .... tried reflasing factory and nope no dice. what the duce?
                  • robskiR
                    robski @xhozt
                    @xhozt try one of oldest firmwares maybe to see if this helps
