    Cardputer worked fine , but something happened on the screen and now a part of it is not displayed.
    FAQS
    8
    5.3k
      MiguelM
      ![alt text](![image url](displayProblem2.png image url))
      robskiR ajb2k3A 2 Replies Last reply Reply Quote 0
      • robskiR
        robski @MiguelM
        @MiguelM looks like rotation isnt right, what is displayed if you just burn easyLoader demo file or latest uiflow2 firmware from M5Burner?
          ajb2k3 @MiguelM
          @MiguelM Looks like the wrong firmware has been burned.
            MiguelM @robski
            @robski thank for your help,
            I did the following:
            1. I loaded easyLoader demo and works fine. However if I l loaded in IDE Arduino (IDE 2.3.4 version) the behavior isn't correct, the screen does not fill correctly as the image indicates the issue.
            2. But strange... I have a second new card: I loaded the easyLoader demo (ok), I loaded the same Arduino source code and this second board works fine.
            Additionally, I bought the screen and the new M5stack board spare parts (M5stackS3 + display), but (1) cardputer it is not correct.
            it's very strange for me.
              MiguelM @ajb2k3
              @ajb2k3 the first card fails, the second card works fine.
              • X
                xhozt
                getting the same here on mine . reflash does not correct.
                • X
                  xhozt @xhozt
                  @xhozt also seems the IR blaster is borked .... tried reflasing factory and nope no dice. what the duce?
                  • robskiR
                    robski @xhozt
                    @xhozt try one of oldest firmwares maybe to see if this helps
