    M5Burner on MacOs Sequoia 15.1 does not work
    UiFlow 2.0
    5
    5
    1.4k
    • B
      bobkummerfeld
      The MacOS M5Burner is prevented from running due to possible security problem.
      It is Intel code but my system is apple chip (M1).
        ajb2k3 @bobkummerfeld
        @bobkummerfeld You need to grant permission to M5Burner to run.
        Apple changed the security to prevent none App Store apps from running and so you need to manually permit access.
        The process is a bit confusing so please google how to permit none approved apps from running on Apple M1 based computers.
        • aivarannamaaA
          aivarannamaa
          Run following command in Terminal:
          xattr -c /Applications/M5Burner.app
          This will remove the quarantine flags from the app.
          DINK74D H 2 Replies Last reply Reply Quote 2
          • DINK74D
            DINK74 @aivarannamaa
            @aivarannamaa I just ran into this issue, and your advice helped (MBA M2 Sequoia 15.2) – thank you!
            • H
              haruhisa @aivarannamaa
              @aivarannamaa
              This solved the problem. Thanks!
