    drawString() - positioning confusion
    3.2k
    • TomKattT
      TomKatt
      Working through some examples to learn how to use the screen on my DinMeter...
      The example code uses the snippet below to display a value manipulated by the encoder knob - the numeric text is always centered on the display...
      DinMeter.Display.drawString(String(newPosition),
                                                    DinMeter.Display.width() / 2,
                                                    DinMeter.Display.height() / 2);
      Researching the functions, it seems like drawCentreString() should do that ??? Shouldn't drawString() reference the top left of the current setTextDatum() command? If I need to display text in a specific area, how do you code that?
      PS - looks like I'm the only one here lol
      • teastainT
        teastain @TomKatt
        @TomKatt Sure, there's lots of us here.
        You have to consider the world is on a 24hr cycle.
        I would help you but it would not be what you want.
        This is TFT_eSPI one of the most famous graphics drivers:
        GFX, LVGL, TFT_eSPI .
        LOTS of reference and examples.
        As I said you have a M5StampS3 which is an ESP32 S3 wth a ST7789V2 LCD, also very common. All small M5Stack products use it. The one from the CardPuter will work in an old StickCPlus.
        Here is the Canvas API:
        https://docs.m5stack.com/en/arduino/m5gfx/m5gfx_canvas
        Have you tried replacing
        DinMeter.Display.width() / 2, DinMeter.Display.height() / 2);
        with literals, like 50, 50?
        Experiment, research, have fun.
        TomKattT 2 Replies Last reply Reply Quote 0
        • TomKattT
          TomKatt @teastain
          @teastain
          Hello again!
          Yes, I've been experimenting and replaced the references to the display width and height with literal values and the result was as expected - the specified xy position is the center of the drawn string. Beyond the confusion of expecting xy to locate the string by upper left corner, the API states this is how drawString() should work...
          drawString()
          Description:
          Draw a character
          Syntax:
          drawString(const char *string, int32_t poX, int32_t poY, uint8_t font);
          drawString(const char *string, int32_t poX, int32_t poY);
          drawString(const String& string, int32_t poX, int32_t poY, uint8_t font);
          drawString(const String& string, int32_t poX, int32_t poY);
          Function argument:
          argument	type	Description
          **poX	int32_t	Coordinate X (upper left)**
          **poY	int32_t	Coordinate Y (upper left)**
          string	const char * / String &	String
          font	uint8_t	1: If use the loaded font
          Function return value:
          None
          • TomKattT
            TomKatt @teastain
            @teastain
            Found the issue - this was hidden in the Setup routine:
            DinMeter.Display.setTextDatum(middle_center);
            The default is top left as expected, this line overrides the code below. Problem solved - user error strikes again lol
            On the topic of different libraries - I note you have suggested the Canvas API before... Is this preferred over the TFT_eSPI API ?
            Thanks!
            • teastainT
              teastain @TomKatt
              @TomKatt BTW, I love your Blown Away by Maxell.
              The ‘Canvas’ is M5’s name for TFT_eSPI !
              Keep up the good work!
