    CoreMP135 install UiFlow2
    Cores
    999
      MCU1536
      After logged in, I followed CoreMP135 Network Management.
      And then I followed CoreMP135 UiFlow2 Quick Start to install UiFlow2.
      It returned below message.
      apt update
      -sh: apt: not found
      Could you suggest me to solve this problem?
      • robskiR
        robski @MCU1536
        @MCU1536 have you added new user?
        M5StickC, M5StickCPlus, M5StickCplus2,M5GO, M5Core, M5Tough, M5Core2, M5 Demo Board, M5Dial, M5Paper, M5Atom, M5Cardputer, M5StampS3, CoreMP135, StamPLC, AirQ
          MCU1536 @robski
          @robski
          I tried to add the user as below result.
          sudo adduser good
          -sh: sudo: not found
          • robskiR
            robski @MCU1536
            @MCU1536 have you enabled ssh in config?
              MCU1536 @robski
              @robski
              I tried the command as below result.
              My IP: 192.168.1.55
              Password: root
              ssh root@192.168.1.55
              root@192.168.1.55's password:
              sudo adduser good
              robskiR ajb2k3A 2 Replies Last reply Reply Quote 0
              • robskiR
                robski @MCU1536
                @MCU1536 can you try putty via usb?
                  MCU1536 @robski
                  @robski
                  I tried it on Putty via USB.
                  Result is the same. It cannot add the user.
                  • robskiR
                    robski @MCU1536
                    @MCU1536 how your initial boot screen looks like? in terminal.
                      MCU1536 @robski
                      @robski
                      After I use latest M5_CoreMP135_debian12_20240919.
                      I can install UiFlow2.
                      Thank you very much for your help.
                        MCU1536 @MCU1536
                        After updated, I restart it. It hang up.
                        The Device Manager cannot find COM Port.
                        I tried to burn image for 2 time.
                        It still hang up.
                        root@CoreMP135:~# pip list
                        Package Version
                        certifi 2025.1.31
                        charset-normalizer 3.4.1
                        distro 1.8.0
                        evdev 1.9.1
                        idna 3.10
                        paho-mqtt 2.1.0
                        pip 23.0.1
                        PyAudio 0.2.14
                        pyserial 3.5
                        requests 2.32.3
                        setuptools 66.1.1
                        smbus2 0.5.0
                        uiflow2 0.0.1rc1
                        urllib3 2.3.0
                        wheel 0.38.4
                        root@CoreMP135:~# uiflow2
                        UIFlow2 running PID: 2974
                        root@CoreMP135:~# uiflow2 enable
                        Created symlink /etc/systemd/system/multi-user.target.wants/uiflow2.service →
                        /etc/systemd/system/uiflow2.service.
                        enable uiflow2 service success
                        root@CoreMP135:~#
                        • robskiR
                          robski @MCU1536
                          @MCU1536 thats my pip list
                          uiflow2 works
                          Package Version
                          bcrypt 4.3.0
                          certifi 2025.1.31
                          cffi 1.17.1
                          cryptography 44.0.2
                          dbus-python 1.3.2
                          distro 1.8.0
                          distro-info 1.5+deb12u1
                          evdev 1.9.1
                          idna 3.10
                          paho-mqtt 2.1.0
                          paramiko 3.5.1
                          parse 1.20.2
                          pexpect 4.9.0
                          pip 23.0.1
                          ptyprocess 0.7.0
                          PyAudio 0.2.14
                          pycparser 2.22
                          PyGObject 3.42.2
                          PyNaCl 1.5.0
                          pyserial 3.5
                          python-apt 2.6.0
                          requests 2.32.3
                          SCons 4.9.1
                          scp 0.15.0
                          setuptools 66.1.1
                          smbus2 0.5.0
                          ufw 0.36.2
                          uiflow2 0.0.1rc1
                          unattended-upgrades 0.1
                          urllib3 2.3.0
                          wheel 0.38.4
                            ajb2k3 @MCU1536
                            @MCU1536 For some reason the sudo command isn't installed by default.
                            By default roots SSH is disabled you need to create a new use and enable SSH on that account.
                            You then need to download the file from the website and copy it to the coreMP135 and run it from there.
                              MCU1536 @ajb2k3
                              After burned with M5_CoreMP135_debian12_20240919.img
                              Don't restart the MCU.
                              I tried the commands as below.
                              1. root@CoreMP135:~# sudo service ssh start
                              2. root@CoreMP135:~# sudo adduser good
                              3. ifconfig
                                eth0: inet 192.168.1.45
                                root@CoreMP135:~# ssh good@192.168.1.45
                              4. CoreMP135 Partition Resize
                              After reboot the MCU.
                              The MCU can boot-up.
                              Thank you for very much for your help.
