    CoreMP135 install UiFlow2
    13 Posts 3 Posters 8.7k Views
    • robskiR Offline
      robski @MCU1536
      @MCU1536 have you added new user?
        MCU1536 @robski
        @robski
        I tried to add the user as below result.
        sudo adduser good
        -sh: sudo: not found
        • robskiR Offline
          robski @MCU1536
          @MCU1536 have you enabled ssh in config?
            MCU1536 @robski
            @robski
            I tried the command as below result.
            My IP: 192.168.1.55
            Password: root
            ssh root@192.168.1.55
            root@192.168.1.55's password:
            sudo adduser good
            robskiR ajb2k3A 2 Replies Last reply Reply Quote 0
            • robskiR Offline
              robski @MCU1536
              @MCU1536 can you try putty via usb?
                MCU1536 @robski
                @robski
                I tried it on Putty via USB.
                Result is the same. It cannot add the user.
                • robskiR Offline
                  robski @MCU1536
                  @MCU1536 how your initial boot screen looks like? in terminal.
                    MCU1536 @robski
                    @robski
                    After I use latest M5_CoreMP135_debian12_20240919.
                    I can install UiFlow2.
                    Thank you very much for your help.
                      MCU1536 @MCU1536
                      After updated, I restart it. It hang up.
                      The Device Manager cannot find COM Port.
                      I tried to burn image for 2 time.
                      It still hang up.
                      root@CoreMP135:~# pip list
                      Package Version
                      certifi 2025.1.31
                      charset-normalizer 3.4.1
                      distro 1.8.0
                      evdev 1.9.1
                      idna 3.10
                      paho-mqtt 2.1.0
                      pip 23.0.1
                      PyAudio 0.2.14
                      pyserial 3.5
                      requests 2.32.3
                      setuptools 66.1.1
                      smbus2 0.5.0
                      uiflow2 0.0.1rc1
                      urllib3 2.3.0
                      wheel 0.38.4
                      root@CoreMP135:~# uiflow2
                      UIFlow2 running PID: 2974
                      root@CoreMP135:~# uiflow2 enable
                      Created symlink /etc/systemd/system/multi-user.target.wants/uiflow2.service →
                      /etc/systemd/system/uiflow2.service.
                      enable uiflow2 service success
                      root@CoreMP135:~#
                      • robskiR Offline
                        robski @MCU1536
                        @MCU1536 thats my pip list
                        uiflow2 works
                        Package Version
                        bcrypt 4.3.0
                        certifi 2025.1.31
                        cffi 1.17.1
                        cryptography 44.0.2
                        dbus-python 1.3.2
                        distro 1.8.0
                        distro-info 1.5+deb12u1
                        evdev 1.9.1
                        idna 3.10
                        paho-mqtt 2.1.0
                        paramiko 3.5.1
                        parse 1.20.2
                        pexpect 4.9.0
                        pip 23.0.1
                        ptyprocess 0.7.0
                        PyAudio 0.2.14
                        pycparser 2.22
                        PyGObject 3.42.2
                        PyNaCl 1.5.0
                        pyserial 3.5
                        python-apt 2.6.0
                        requests 2.32.3
                        SCons 4.9.1
                        scp 0.15.0
                        setuptools 66.1.1
                        smbus2 0.5.0
                        ufw 0.36.2
                        uiflow2 0.0.1rc1
                        unattended-upgrades 0.1
                        urllib3 2.3.0
                        wheel 0.38.4
                          ajb2k3 @MCU1536
                          @MCU1536 For some reason the sudo command isn't installed by default.
                          By default roots SSH is disabled you need to create a new use and enable SSH on that account.
                          You then need to download the file from the website and copy it to the coreMP135 and run it from there.
                            MCU1536 @ajb2k3
                            After burned with M5_CoreMP135_debian12_20240919.img
                            Don't restart the MCU.
                            I tried the commands as below.
                            1. root@CoreMP135:~# sudo service ssh start
                            2. root@CoreMP135:~# sudo adduser good
                            3. ifconfig
                              eth0: inet 192.168.1.45
                              root@CoreMP135:~# ssh good@192.168.1.45
                            4. CoreMP135 Partition Resize
                            After reboot the MCU.
                            The MCU can boot-up.
                            Thank you for very much for your help.
