    M5Stack - Simple Applications Menu + some APPs
    40 Posts 10 Posters 246.3k Views 6 Watching
      TomSuch @JJ
      @jimit Thank you for the positive bond ...
      • JJJ Offline
        JJ @TomSuch
        @tomsuch
        No problem Tom. Very much deserved !
        Have got a wifi scan working with this under the Apps menu... but need to more spend a bit more time to get the screen output layout right... so each scan displays from the same line each time.
        • m5stackM Online
          Awesome, i think we should do some offical support about this good idea.
          T 1 Reply Last reply Reply Quote 3
            TomSuch @m5stack
            @m5stack Thank you. I'd like to create something like a Swiss knife for makers.I like M5Stack and I'd like to create applications like a simple pocket oscilloscope, multimeter, I2C / SPI sniffer, signal generator, and so on. I think M5Stack is a platform with a lot of potential. Regards..
              TomSuch
              New version:
              Added:
              • APP - GY-512 (MPU6050) - gyro/accelerometer
              • APP - variable speed Serial PASS-THRU USB<->UART2
              • SYSTEM - System Informatins (CPU Speed, Flash Size, Flash SPEED, SDK Version .......)
              • Serial Commands - WiFiScan, I2CScan
              • m5stackM Online
                @TomSuch I got your mind, and similar to me, i really hope it like a swiss knife. useful and meaningful.
                  Kryten
                  I get errors on all
                  [code]
                  #pragma mark
                  [/code]
                  Will comment out and try again
                    TomSuch @Kryten
                    @kryten Please specify the error. Arduino version. Take PrintScreen.
                    Do you have installed M5.libraries ? ESP32 libraries ?
                    • reaper7R Offline
                      reaper7
                      @tomsuch 在 M5Stack - Simple Applications Menu + some APPs 中说:
                      APP - GY-512
                      very nice system!
                      APP - GY-512 works also with built-in MPU9250 :)
                      Can You modify TIM MEASUREMENT APP?
                      S/S button should 1.START->2.STOP->3.START without reset between 2 and 3 step...(something like continous measurement with pause). For reset value we have RES button
                        TomSuch @reaper7
                        @reaper7 Hi, thanks for the subject. I edited the application of the stopwatch and is already out. Regards...
                        • JJJ Offline
                          JJ
                          T 2 Replies Last reply Reply Quote 0
                            TomSuch @JJ
                            @jimit Hi, good work. But I did not find the code on your git ...
                            • JJJ Offline
                              JJ @TomSuch
                              @tomsuch
                              Oops... sorry bout that. Have added them now....
                                TomSuch @JJ
                                @jimit OK, I'm going to check it out ..
                                  TomSuch @JJ
                                  @jimit Hello Jimi, I have redesigned your WiFi scanner application and there is a new version M5Stack-SAM with this APP out there.
                                  https://github.com/tomsuch/M5Stack-SAM
                                  • JJJ Offline
                                    JJ @TomSuch
                                    @tomsuch Thanks Tom... looks much better ! One thing - for me once the scan is done it lists the networks but the screen refreshes immediately before they can be read.... tested on two different M5s ? Strange if it's not happening for you too. Hate to respond with a negative when you've done such nice work. BTW, the system info page you added is great to have and the others too. Awesome work.
                                      TomSuch @JJ
                                      @jimit Hi Jim, I think I found and remove the bug. Can you try a new, fixed version? Thank you...
                                      https://github.com/tomsuch/M5Stack-SAM/
                                      • JJJ Offline
                                        JJ @TomSuch
                                        @tomsuch
                                        Awesome... all wifi scanner functions working perfectly - thou i couldn't test the page function due to lack of networks... excellent work Tom !! Thanks for making it happen.
                                          TomSuch @JJ
                                          @jimit No problem Jim. Regards....
                                            kaotiklabs
                                            Would be awesome to have a generic menu system so you could focus only on core development.
                                            I have tried to use yours for my app but had no time to fully understand it.
                                            Could you write a little doc explaining how can we use it in our apps?
