    PaperS3 with UIFlow2 v2.2.5 binded in M5Burner but not recognized in UIFlow2 online (SOLVED)
    UiFlow 2.0
    587
    • PaulskptP
      Paulskpt
      Hi, using M5Burner I flashed my M5PaperS3 (v1.2) with UIFlow2 v2.2.5. I binded this device in M5Burner to my account (being logged-in). However, when using the online version of UIFlow2 the M5PaperS3 is not recognized as if it was not binded. Also on the main page of UIFlow2 on the M5PaperS3 below the word "ACCOUNT" there is no information.
      See the images
      Anyone has an idea what could be the reason why a device binded to ones account is not recognized as such?
      In the mean time I have cloned and built uiflow-micropython. I am now using the M5PaperS2 in Thonny.
      Coding keeps your mind going
      • robskiR
        robski @Paulskpt
        @Paulskpt usually after binding only req is to load firmware with wifi access and device is visible as online in devices list
        M5StickC, M5StickCPlus, M5StickCplus2,M5GO, M5Core, M5Tough, M5Core2, M5 Demo Board, M5Dial, M5Paper, M5Atom, M5Cardputer, M5StampS3, CoreMP135, StamPLC, AirQ
        PaulskptP 1 Reply Last reply Reply Quote 0
        • PaulskptP
          Paulskpt @robski
          @robski thank you for your reply. After binding I flashed the UIFlow2 for the M5PaperS3. Then I opened uitflow2.m6stack.com, however, at that moment I had my PaperS3 connected to my desktop PC (MS Windows 11 Pro) via USB cable. I don't know if it makes a difference if the device is connected via USB or via WiFi. I'll go to make that check.
          Additional info:
          First, in the online Uiflow2.0 page I deleted the existing registration of the M5PaperS3, so M5Burner would go to ask me to bind this device to my account.
          I reflashed UIFlow2 using M5Burner V3 (beta-win64) (I googled for an older version however I didn't find). During the burn process inside M5Burner I was asked to bind the deviced. I did and accepted the default option "Public". After a successful flashing I disconnected the M5PaperS3 from the desktop PC. I rebooted the M5PaperS3. I saw on the display of the M5PaperS3, main window, under "MODE": "Private" and under "ACCOUNT": "None".
          I remember from using other M5Stack devices in Uiflow2, that it can take some seconds, after the device has connected to the M5stack server, to update its account information on the Uiflow2.0 webpage and on the device itself.
          However, this time with this M5PaperS3 I saw no account info update. On the desktop PC I started a Uiflow2 session within a Chrome browser. When I clicked on the device info, the Uiflow webpage showed MAC-address, a TOKEN value, a device-ID and Permissions: "Public". On the M5PaperS3, main window, I saw that the info did not change. It showed the same data as I wrote above.
          I created a short video of the boot process. In this video one can see that on the bottom line, left side, two icons appear. Left: a WiFi-icon. Right next to it, a Server-icon. Initially the Server-icon looks like what I interprete as "connected". A few seconds later this Server-icon changes. From then on the Server-icon has a "x" in it. This I interpreted as "disconnected from Server".
          In the Uiflow2.0 webpage, the icon of the M5PaperS3 device is shown with a red dot and a red question mark ("?") inside of it. When I clicked on that logo, there appeared on the right-top of the UIflow2.0 window a pop-up message window saying "Error: the device type is unknown".
          I don't think there is a WiFi problem with this M5PaperS3. Why? Because, after I had built and flashed uiflow-micopython firmware to this M5PaperS3, I created a MPY sketch that connected to a WiFi Access Point here in the house and have the device connecting to a NTP-server and ask for an NTP-datetimestamp which was received OK. Conclusion: the WiFi of this M5PaperS3 is working.
          Sofar my response. I don't know what I can do more. Maybe create an issue on Github.
          FYI here is a link to the video.
          Regards,
          Paulskpt
          • robskiR
            robski @Paulskpt
            @Paulskpt i use devices on wifi and connected via usb in same time, uiflow2 online sends project via wifi when terminal via usb showing what is going in same time
            PaulskptP 2 Replies Last reply Reply Quote 1
            • PaulskptP
              Paulskpt @robski
              @robski Thank you. I just flashed and registered a M5StickC-Plus2 with UIFlow2. It was recognised in online UIFlow2 session.
              • PaulskptP
                Paulskpt @robski
                @robski Update: from within an online Uiflow2.0 session I used the M5Burner. I choose to not to burn the v2.2.5 but the v.2.2.4 hotfix. And this went OK. The main page of the Uiflow2 on the M5PaperS3 is now showing MODE "Public" and ACCOUNT my account e-mail address.
                See images.
                Problem solved. I didn't find a place in Github/M5Stack where I eventually could create an issue. However, we are here in UiFlow 2.0.
                Thanks for your assistance robski!
                Paulskpt
                • robskiR
                  robski @Paulskpt
                  @Paulskpt I remember I had similar with CoreMP135 when uiflow2 firmware was loaded in to it, it won't display email and account status on display but..but it was connected and visible as online in web uiflow2 in device list
