    PaperS3
    5 Posts 2 Posters 2.1k Views
      paydogs
      Hi
      I just purchased a PaperS3 to tinker with, I intend to use as a Homelab server monitor.
      Anyways, when I unboxed, turned on, its started, the timer ticked, showing the battery charge, found wifi networks, etc.
      I downloaded the M5Burner app, it detected the device as COM4. Downloaded and installed the UIFlow2.0 PaperS3 app, but after start its just turns off. I tried it also with PaperS3 Factory Test, the same. Tried to erase the firmware and upload after it, still...
      The device was never connected to a power brick, just the computer (tried to flash on windows and mac). And it turns off even if I keep it on plugged in.
      https://youtube.com/shorts/uUjxZwcYAr4
      Any ideas?
      Andras
        paydogs @paydogs
        @paydogs Never mind, i charged for a long time and it looks like its resolved the issue. However I try to flash it again with something and check if it screws something again.
        • felmueF Online
          felmue @paydogs
          Hello @paydogs
          I was just about to suggest that from your video it looks like the battery might be flat.
          Glad you figured it out.
            paydogs @felmue
            @felmue it was just curious that the moment I started to flash, made it flat...
            What is the proper voltage for it?
            • felmueF Online
              felmue @paydogs
              Hello @paydogs
              my M5PaperS3 running the factory test shows about 4.19 V when fully charged and still on USB-C. When I remove external power it drops to about 4.12 V.
