    34 Posts 5 Posters 23.6k Views 1 Watching
      adamm5 @adamm5
      @adamm5 Ive rebuilt this project from scratch and can confirm that ignoring the i2c load error is possible even when using the AIN i2c unit and PAhub unit. This seems to be a change to my earlier experience but perhaps something else was happening with the code.
        Kenzo @robski
        Thanks everyone for your suggestions!
        @robski - I went back to my Tube example and the only one that worked was the ADC parameter to pull data. (I used 12bit)
        So I looked at the UiFlow1 example for the Tube Pressure and tried to duplicate it. The program now runs BUT I am not sure if I am using the correct math conversion to convert the raw data from the ADC parameter into Kpa. I have searched a couple of sources BUT can't seem to find documentation that fully explains how to correctly calculate Kpa with the ADC parameter to Kpa...
        Does anyone know were to get really good documentation on the tube pressure sensor that explains how to properly calculate Kpa using the sensor with ADC option?
          Kenzo @Kenzo
          So if I assume the ADC 12 bit option will give me 4,096 different points and the ADC 16 bit option will give me 65,536 different points maybe I can come up with a formula ( using the voltage - Pressure graph) of how to calculate Kpa when using ADC option for the Tube pressure... Everyone I am just thinking out loud so don't bash me too badly... LOL!
          • robskiR Offline
            robski
            try below
              Kenzo @robski
              @robski Thanks for replying! With nothing connected to the Tube pressure sensor, I am getting a RAW value of 3,287 (12 bit option selected in the ADC parameter).
              In regards to a 3.6V reference, where is that in the documentation?
              I think we are getting close to solving this problem!
                Kenzo @Kenzo
                @robski - I stumbled across this youtube video about an Arduino Pressure Sensor and was thinking about testing a version of his method for coming up with a calculation...
                https://youtu.be/UrqPxwsPWGk?si=4Ho9CQwpoFZstMBk&t=321
                • robskiR Offline
                  robski
                  with your raw value as 3287
                  sensor range -100 to 200
                  analog range 0 to 4095
                  your calculated pressure should be around 140
                    Kenzo @robski
                    @robski - hmmm.... Well that raw value was with nothing connected to the Tube Pressor sensor. Because nothing is connected to the tube pressure sensor I would assume it would be closer to 0 Kpa... 140Kpa is a big difference from 0 Kpa... I wonder what we are missing?
                      Kenzo @robski
                      @robski I keep coming up with 140Kpa also...
                      We must be missing something...
                      • robskiR Offline
                        robski
                        just connect voltage to sensor and measure what voltage it is giving out between output pin and ground. for 0 kPa your raw Analog value should be around 1300 i think
                        K 2 Replies Last reply Reply Quote 1
                          Kenzo @robski
                          @robski - I think you hit on something there! I measured the voltage between the ground and the sensor and it came to around 1.1v which according to the graph should be around 0 Kpa. (see attached photos) Something is definitely strange...
                            Kenzo @Kenzo
                              Kenzo @Kenzo
                              Also here is the formula I was using to calculate Kpa
                              So for 12 bit parameter, this gives a kpa resolution of 300Kpa/4096 bits or 0.0732421875 kpa/bit (73.2pa/bit)
                              x = ( (0.0732421875 kpa/bit * Raw Value bit) - 100Kpa)
                              x = ( (0.0732421875 kpa/bit * 3287 bit) - 100Kpa) = 140.7Kpa
                              For the 16 bit parameter this gives a kpa resolution of 300Kpa/65536 bits or 0.00457763671875 kpa/bit (4.6pa/bit)
                              x = ( (0.00457763671875 kpa/bit * Raw Value bit) - 100Kpa)
                              x = ( (0.00457763671875 kpa/bit * 52600 bit) - 100Kpa) = 140.8Kpa
                                Kenzo @robski
                                @robski I sent an email to M5Stack Support about the possible issue with the Tab5 and Tube Pressure sensor BUT no response so far....
                                • kurikoK Offline
                                  kuriko @Kenzo
                                  @Kenzo
                                  This is an ADC problem. We are fixing UiFlow2 codes. Please be patient.
                                    Kenzo @kuriko
                                    @kuriko Thanks Kuriko for responding and taking a further look into the issue! Looking forward to testing out the updated version of UiFlow with the fix!
                                    I will now wait quietly and patiently while your team works on an ADC fix.
                                      Kenzo @kuriko
                                      @kuriko Just finished testing the latest release of UiFlow (v2.3.2 ).
                                      The Kpa readings was better this time but the accuracy is not there yet... See attached photo.
                                      Hopefully the next release will improve the accuracy of the Tube/Air sensor and Tab5...
                                        Kenzo @Kenzo
                                        Just tested another release of UiFlow (version 2.3.3) for the Tab5... Unfortunately, I am seeing the same results that I saw with Version 2.3.2... -16Kpa without any air tubes connected to the M5Stack Air Tube sensor... Along with the i2c driver install error...
                                        Hopefully M5Stack Team is getting close to resolving the issue... I was planning to use the Tab5 project I was working on for the M5stack Innovation contest but it looks like that will not happen due to the issues I am running into with finding an air tube sensor that will accurately work with the Tab5... Oh well... Hopefully the M5stack team will release an upgraded Air Tube sensor soon that will easily work with the Tab5... Until then, I will keep searching for a solution....
